Can I use a starter solenoid as a relay for full time use? I am having a problem with my relay for my FASS pump getting really hot and I am thinking about using a starter solenoid as a relay for the pump. I have rewired everything a couple times thinking that there was a proble with my home made wiring harnes but the relay is still getting hot. I think the problem is that I am running on w85 and it is harder for the pump to move so it is drawing more amps and causing the heat. Let me know if you guys have any other ideas for a relay.
Thanks
Vic
Thanks
Vic
