Stripped Threads Cast Iron
Atsah
Maine
Well I stripped the threads on my Warn winch, I don't know much about cast iron, do I need a new housing or can I tap this thing? It was 0F and as usual I cranked two bolts to tight..:doh:
neverkickn
AR
Cast can be repaired with a helicoil. That may be your best bet if you can access it to prep the hole for the coil.
Zmann
threads aren't cast into the part they are tapped anyway so if u want to up size you know the routine for that process
Zmann
yes u can just re drill and tap
that's how they were done originally
Zmann
helicoil/timesert is good when the part won't accept a larger fastener but they cost more IMHO
Atsah
Maine
Okay, I have plenty of material to go bigger... I thought I was screwed when I stripped them out.. The winch was mounted incorrectly so I took it off, put in on right and stripped them out..:doh:
Atsah
Maine
