Suspension question.
SleeperDuty
Ok guys just put on new wheels and tires, I'm have a little bit of a rubbing issue I already trimed the inside of the fender as much as possible. I really DO NOT want to lift the front end, But is there something out that can be put on to lift the front when in the city when need a little extra clearance for turning and that can lower it back down to stock hieght on the highway? If not whats the shortest leveling kit/spacer available? I think 1-1.5 inches of lift in the front will be enough to stop the rubbing and give enough clearance.
cfdeng7
CT
4 linked air ride ftw!! But you can get .5" all the way to 3" front spacers
wetnsloppy4x
Notus, ID
I suppose you could get a set of airbags for the front. LOL
