Suspension torque specs 2015 f350 SRW
TMCrocker
Hello, i recently purchased a 6 inch rough country radius arm lift for my truck, i will be installing it this thursday. I'm having some trouble finding the torque specs for everything, does anyone happen to know? The only thing i have been able to actually find is the specs for the rear ubolt.
ncollins64
winchester springs, tn
Tight! That trac bar up front is stupid tight also. Forgot the specs but I had to use a breaker bar to get it tight enough so it wouldn't move and make noises.
Jgon08
I think the Trac bar is 400/lb if that helps that's the only one I can remember.
Jomax
Arizona
Radius arm bolts are 222ft lbs. All three.
