symptoms of hpop failure??
SoCalPSD
Riverside Ca
I couldn't tell you but at swamps site under their faq and how to section there is a write up on it.
SoCalPsd-Corey
DcMoore
Amarillo, Tx
What is your truck doing? Also do you have a high pressure oil gauge hooked up ... That would be the best way to figure it out.
Tom S
SoCalPsd-Corey
This is the info from the guys at Swamps Diesel about the HPOP so you do not have to look for it.
How to check if my HPOP is good
Before we help you decide on a style of injector, it is very important that we (both) know how good (or bad) your HPOP is.
There are 2 ways to measure the oil pump's performance.
If you have access to a scantool, hook it up to the trucks OBD connector, and go to the "datastream"...scroll through the sensor values, until you find ICP (or injection control pressure)...this is your HPOP's "oil pressure".
***NOTE: if you are running any kind of "box" such as the "Edge EZ" or the "Banks Six Gun" you either have to remove the aftermarket jumper harness/plug at the ICP sensor, and reconnect the factory harness by itself. If you are running a home made "10k mod", etc...which plugs/taps into the ICP sensor wires (or connector pins), you will have to remove it as well, or proceed with getting the parts together to run the mechanical gauge, as the scantool will not receive accurate data from the ICP sensor if its signal is being modified from any one of thes "ICP foolers".
To test the HPOP's output, you will be looking on the scantool for the line labeled "ICP" and it's units should be in psi not volts. Some scantools measure ICP in kPa (kilopascals) which you can convert to psi after you take your measurement in kPa.
1kpa = 0.145psi
(for example 19,310kPa = 2800 psi)
Put your chip in its' highest setting, and go out on the interstate (while having someone watch the ICP value on the datastream) and start at about 60mph...
FLOOR the pedal, and stay in it, 100% from ~60-90mph...what you're likely to see (on the scantool) is that the ICP will spike up rather quickly, to 2800-3000psi or so, and then the longer you stay in the pedal...the ICP will slowly drop and drop and drop...the ICP will eventually stabilize (stop dropping).
WHERE the ICP levels off can be some indication as to the condition of your HPOP.
If your truck can maintain 2800+psi then you are one of the FEW folks that have a terrific HPOP.
I would estimate that 90% of the Power Strokes can only maintain ~2200(+/- 200)psi of HPOP pressure, or ICP...5% are above 2600, the other 5% are below 1900psi...
depending on how low (or high) of ICP you are able to maintain will greatly affect which model of injector I would recommend.
If you don't have access to a scantool, then go to your local hydraulic supply house, and have them make you up a mechanical gauge. You might spend $60 or so on high pressure hose, fittings, and a quality 0-3500psi liquid filled gauge....but having this hose available for future diagnostics might be more valuable than you think.
The hose which you will need will need to be about 40" long, rated for (minimum) 3000psi working pressure (12k psi burst rating!) with the gauge on one end, and a #6 female JIC swivel fitting crimped onto the other.
You will also need an individual fitting to screw into the head to go from the head to the hose.
This single fitting will be a 90degree fitting # 5 "male boss" (sometimes called # 5 o-ring) on one end of the 90, and a # 6 male JIC on the other end of the 90. Our local hydraulic shop would label such a fitting as 5MB-6MJ90
"JIC" is nothing special...it's just 'hydraulic talk' for a 37degree flare fitting...standard hydraulic stuff here...nothing rare by any stretch.
Looking at the top of (either) cylinder head, you'll see the factory stainless braided oil lines (one to each head) then you'll see a few bronze colored plugs... (Engine off, of course) Using a 5/8" wrench, remove any one of the bronze plugs, and install the 90deg fitting into the hole. (save the plug for reinstallation , after testing). and the O-rings are reusable, unless brittle, cracked, etc...
The single 90deg fitting will have a "jamb nut" on the O-ring side...screw the fitting into the head, "aiming" the 90 away from the turbo, intercooler pipes, etc...and then tighten the jamb nut, to "squish" the O-ring also locking the 90 from "spinning" around as you attach the swivel end of the hose to the 90. No sealants, loctite, or teflon tape are needed on "JIC" or O-ring fittings...and don't overtighten them...usually about 180degrees with a wrench past finger tight...check for leaks prior to getting too far from home...
run the hose, away from moving parts, electrically conductive junk (like batteries, glow plug relay, starter relays, etc) ..and just route the hose up through the cowl toward the windshield...for short term testing purposes, we just lay the gauge up under a windsheild wiper, and go drive...testing it just like I describes previously...chip in the highest setting, floor the truck, etc....
If you can maintain 2800+ psi of ICP, then any injector 250cc's and under will perform exceptionally well.
If you can maintain 2400psi then that's not bad, not great either.
2200psi is mediocre, and full performance from any injector will not be achieved with that HPOP, though power WILL go up with nearly any injector, driveability (excessive smoke) might be an issue.
If you cannot maintain 1900psi, you might seriously consider an aftermarket dual HPOP system, or our Gen3 HPOP. Nearly any larger injector is going to make the truck feel sluggish, and smoke excessively.
lsmith33
Katy, TX
its been runnin fine but over the last week i noticed longer cranks to start. then it started an would die then start right back up no problems. now the other night it started went o move the truck NO power. turned it off now it wont start, not buildin any presure on the dash gauge while crankin when it used to register something now nothing. fuels good inj good. checked hpop res. an was about 3/4 fulls i topped it off still nothing. not leaking oil anywhere i can see.
Tom S
Is the tin nut on the IPR for a quick easy check?
Do you get wait to start light?
Do you have access to a scan tool?
Charles
Firing up then dying sounds like lube oil deficiency.
Is there oil in the engine... how long has it been in there....
Sounds like the reservoir might be draining down, or your lube oil circuit is deficient, or the pump is puking oil straight through. I've had one do that.
If you're not reading oil on the dash then you've got no lube oil pressure. Firing up and dying is classic lube oil starvation.
CGMKCM
Randolph County, NC
You might look at engine LPOP oil pressure. I remember reading somewhere that if the LPOP is going bad it can cause symptoms like you are describing.
lsmith33
Katy, TX
the nut is there, yes get a wts light, no i dont. the hpop was a lil low added oil no change. its proly been 4k miles since last oil change.
Charles
If you crank and crank and never get lube oil on the dash then there's no need in worrying about the high pressure pump.
Fwiw, it sounds like a classis lube oil problem. A truck firing up then getting muffled and losing rpm and dying is classic lube oil starvation.
Charles
ok so where do i go from here??
You need to verify lube oil. Make up a gauge on a length of hose and connect it to the reservoir atop the front cover and check the pressure. Unplug the 42 pin connector at the driver's side valvecover with a 10mm socket and crank the engine over with with good, hot batteries on a charger and if you can't get pressure then you need to start thinking about a scored front cover, or worn gear pump, cracked pickup tube or maybe even a cracked block and things along those lines as to why you can't build lube oil.
One other option is that the high pressure pump itself is bypassing all the flow directly through itself. I've had one do this in the past. Wouldn't build lube oil and obviously wouldn't fire. Swapped out the pump and lube oil shot to 40+ and it fired right up.
If you've got a spare pump handy, or a loaner pump to try then you can give that a shot.
lsmith33
Katy, TX
ok thanks i'll give that a shot. whats weird one day i checked the hpop res. an it was full and put a new fuel filter in then within the next 100 miles it started messin up an then the res was low...i jus cant seem to catch a break with this truck
SkySki Jason
N. GA Mountains
It would be ideal to know ICP and IPR duty cycle while cranking. (if ya have LPO) I had a malfunctioning IPR that caused a no-start issue - but got ZERO warning, truck died and would not re-start. I had something like 70psi HPO and 67% DC... Disassembled, cleaned and reassembled IPR and never had problem again.
Charles
You would have had lube oil pressure with sufficient cranking though. If he can't produce lube oil, then nothing the IPR does even begins to matter.
lsmith33
Katy, TX
i messed with the truck late last night an one thing i noticed was that after alot of crankin it will build pressure on the dash but not for long. plus it sounds like its trys to start but never enough to stay running. dont kno if this helps :shrug:
00f3fiddy
Greene Co. GEORGIA
Check your batteries. Mine just did the same thing. Batteries tested good and spun the engine over good. Put 1/2 qt of oil in resivior. Replaced cmp with 1 I had. Truck started spinning a little slower so I put the jump box on it. Fired right up. I put 2 new Batteries in it that I had at the house and Knock on Wood havent had a problem yet. It could have been just coincedence. Good luck with it!
