Torque converter noise
Rmartin-97
Mcarthur ohio
Is it normal for your torque converter to make a noise in neutral but once in gear you hear nothing? It's a dpc triple disk.
Dzchey21
wyoming
what kinda noise? I would say no but it might not be the converter it might be because its in neutral and everything is free spinning
Crack85
Midland, Tx
Are the bolts that attach the torque converter to the flexplate torqued to spec?
Mine did the exact same thing until i tightened/torqued all the bolts and the noise went away.
pdumont01
CT
Does anyone ever honestly torque the converter nuts? I always go all the way with my 3/8 air ratchet and then just check them by hand to be sure I got them all. Just curious.
Crack85
Midland, Tx
Torqued mine after it made noise... Not sure if its common or not.
pdumont01
CT
Yeah through the drivers side where the rubber plug is. Sometimes a long extension and 3/8 impact.
does it sound like marbles rolling around in a steel coffee can? if so, its prolly converter or flywheel.... at least thats how you diagnose the old trucks.. lol
