Tay5985
Last night getting on the freeway i felt my truck have a really bad shift flare from 2nd to 3rd. kept doing it then later last night it got bad enough it would go through 1st 2nd then when it would go to 3rd and feel like someone put the brakes on like the trans was binding up. I came to a stop and when i went to take off its like my truck was in neutral. rev'd it up a bit and it tried to move. shut it off started it back up it clunked into first and started to go till it hit 3rd again and did it all over. got Codes P0766 and P2703.. Talked to the trans guy at the local dealer he says its the Direct Clutch and it needs an overhaul. Any help would be appreciated
