tuning help with my truck
08KingRanchF250
wallburg, nc
currently my single 72mm 6.4 is getting some fueling mods and id like to try out something other then h&s/kem, but so far my truck wont accept the sct tuner, it just throws it into limp mode after one wot run.. looking for something custom as i have the following:
72/83/.9 a/r batmo
100% over mpd nozzles
studs
dual fuelers
rcd stage 1 cam/springs
suncoast mid stall HD converter/billet tranny
thanks in advance..
nickg3130
West Long Branch, NJ
Innovative
Edit-sorry didn't read that sct won't work on your truck. I'm sure it has something to do with updates or flashes but someone will probably chime in and tell you what you can do.
Tree Trimmer
so you come into the gearhead section, to say go to innovative?
did the short bus forget you this morning?
nickg3130
I didn't "come" to the Gearhead section I just read the topic off of the latest posts on my phone and didn't see where exactly this was posted. My bad. Can't really go wrong with either one though to get back on topic.
powerstrokin15
Charleston, WV
pm matt.. hell get you setup. he should be able to make it work as he writes his tune from the ground up by truck individually.. like strategy and all
powerstrokin15
Charleston, WV
I think he needs to tune to a sct device though.
but like i said, matt building from the ground up-maybe with his specific truck he could change some things to make it work. i realize its with SCT.. i run it.
if you dont wanna change just call mike@KEM and have him set you up. hes usually really cool with changing things.
08KingRanchF250
wallburg, nc
Yea ive Tried the innovative canned "custom" tunes that allows u to change a few paramatters but not I havnt Tried a ground up custom tune.. ill shoot yall an email
