Turbo coolant, where is the outlet?
HOUTX01X
I recently replaced the leaking inlet tube and connector. That is all good with no leaks. Looking with a mirror I am seeing some seepage on the back right of the turbo (left if you are facing truck). Is there another connector on the back side or could the seal be worn? Ive searched and all I have seen was in reference to the inlet tube leaking.
Is there a diagram showing the travel of coolant?
Trying to decide if I should knock it out or ride it out until I swap turbos
Thanks in advance
Dzchey21
wyoming
The return is through the turbo pedestal like the oil drain. When swapping turbos you have to make sure you drain the coolant as well.
HOUTX01X
Thanks. It appears to be seeping out around the pedestal opposite of the inlet location. If thats the case I'll hold off on fixing it and just swap the new turbo in.
