got an obs turbo that's starting to pump a little oil, and thought I'd upgrade a little while I'm at it. I took in on trade a 99-03 stock turbo a while back and was going to put that on. Took the turbo apart and sent the turbine wheel and new wicked wheel to be balanced. When I started to clean parts while the shaft was being balanced, I noticed that there was a crack in the turbine housing. I've also got a van turbo in the "extra parts" pile. Was thinking of taking the van turbine housing and putting it on the sd cartridge. It looks like it will bolt up. From what I can tell, this would give me more charge air, a 1.15 turbine housing, and no waste gate. I've also put in stage one injectors intercooler a while back. Planning on changing the up pipes and intake to the sd. This is a work truck/ dd and do have a trailer on it a lot. Was a little concerned with no waste gate boost might get a little high. Anyone else see problems? Any suggestions or advice would be helpful and appreciated!!
