4EverBoosted1
- Joined
- Jan 29, 2012
- Messages
- 1,724
- Reaction score
- 0
So... Since I got my truck running I installed a set of the Triton v3 LED switchback turn signals in my headlights.... Very cool product, but I could never seem to get them to work correctly.. So after dealing with them lighting up the wrong colors at the wrong times along with HYPER-flashing when the Vleds says they do not cause hyper flash since they have built in resistors, I took them out and went back to stock amber bulbs... NOW.. here is my issue. It seems that one of those little bastards caused some sort of short circuit in my right light because now the truck hyperflashes and thinks the bulb is out, even with the stock bulb back in. I have changed the bulb, flipped it around, checked ALL fuses, and all to no success at getting it to blink normally again... The running light function works, but as soon as you turn the blinker on, the light just stays orange and the inside dash hyperflashes. Also when you lock the truck, the left side parking light does its flash and the "broken" one does nothing.
I have done some research and it looks like the BCM has turned off my blinker circuit and now I have to have my buddy at the dealer see if he can reset the BCM so that I can get my blinker back for inspection lol....
