Wingnut
- Joined
- Dec 10, 2011
- Messages
- 117
- Reaction score
- 0
Replaced the water pump and the idlers and the belts while I has there. Get everything buttoned up and fill it up and now no heat and if I drive it it gets hot but I will cool down if left idle. First question this is a ford pump could I have the wrong pump? Im thinking its an air bubble in the system. 6k ago when I had the cab off I changed the coolant and didnt have a bit of problem with it then. Any way to bleed this without a rad vac?
Sent from the cookie sheet...
