Jeff@Spartan
Ok, so I have been hearing some weird creaking and popping noises from the underside of my truck. Some times it sounds like it's from the front and other times it sounds like it's from the rear. It happens when I am rolling at a slow speed and brake to a stop, when I am stopped and begin to accelerate, when I go over a bump (speed bump), or when I make a turn where the truck flexes a bit. That is when the creaking occurs.
I get the pop noise, almost as if the truck jolts or shifts a little when I make right or left turns. It mainly happens when I make left turns, but will occasionally happen on a right turn. Like the creaking, it is usually when the truck flexes. I thought it might have been a cab bolt, but we checked them all. I can't tell if it's suspension related though. My suspension is 100% stock other than an Icon TEI up front with Bilstein shocks. It was doing this prior to the install of those, so I know it's not related.
I can't seem to put my finger on anything else, but it is driving me nuts. If anyone has anything for me to check, that would be great! Thanks in advance!
