BuiltPowerStrokeTough
Not exactly sure what could be causing this, but looking for people with 15-16s to describe their idle and if theirs does the same thing.
I first noticed it around 250 miles on my truck (may have done it the whole time) and has continued since. Some parts fell off my truck around 600 miles, so tuning or anything hasnt caused this. Truck has almost 1000 miles on it now. What is happening is there is like a weird vibration/shudder at low idle, while in park only, and seems like its worse when the engine/trans are below operating temps (engine oil temp 150 or below with the trans temp 150 or below). There is no fluctuation in the idle, and when the trans and engine are up to temp it isnt really noticeable. The weird vibration/shudder is not constant and doesnt make noise. You can notice the vibration up until about 900 rpms while in park. The best way to to describe it would be that its on and off every 1 second. Like a shudder thats coming and going every other second. So itll shudder for a second, then run smooth for second and then repeat. When you put it in drive, it goes away. There is also no driveability issues at all.
Its irritating to me cause my 2011 idled smooth as butter, youd think the brand new truck would idle equally as smooth. I believe there is something going on, but it hasnt got better or worse the more I drive it. I know that on the 2015+ they did change the front damper and the fan clutch, not sure if that has anything to do with it. I dont believe this is engine related as the RPMS are running perfectly smooth. It almost seems like it would have to be external like a damper, fan clutch, torque converter or something.
Anyone else ever had this happen or know what they did to fix it?
