What AE found on my truck!
juniort444e
Slippery Rock, PA
I have some pictures of what it said, just having computer and phone problems tho. This was teh 5th time i tried to make this page. hope it works.
AE says, i have a cylinder #2 injector circuit contribution/balance fault P0266
I also have a 2-3 shift fault as well. And thats no lie, becuase it does shift horrible from 2 to 3.
There are a few other i will post up about, but those to are my main concerns.
What do you think, is it something bad? Fixable?
juniort444e
Slippery Rock, PA
P0782 2-3 malfunction
P0733 Gear 3 Ratio wrong
P0732 Gear 2 Ratio Wrong
I read somewhere that some valve in the valve body had a burr on it, the guy shaved it off and fixed the problem.
Blowby
Jasper 4r100 on my 2001.
Well that problem is solved.
LOL
How many miles on the injectors?
Did you check the valve cover harness? If it's the first or last number on the bank it could be that the harness is just pulling away on that side. If you have the VC's off check the inside connector and ohm the wires to #2 and compare it to the other injector wires.
juniort444e
Slippery Rock, PA
LOL
Tell me about it. :fustrate: Should be problem free soon, i hope.
I did not check anything yet. I do believe these VC harnesses are the originals, so im guessing they might need changed anyway.
Thanks for the advice. I will do that before i decide to buy new ones.
