I would suggest 150% nozzles as well unless you want to run crazy timing to dump a smaller nozzle. Based on what I've seen with flow benching a 100% nozzle, we were getting about 95-98cc/ms in a 1000 shots at 4000 psi of ICP. Haven't done much with the 150s yet but based on the math you should be able to dump a 350mm^3 body in the 2.5 range ms of PW as long as something else in the injector doesn't hold you back. Best of luck either way ya go man.
