OK guys looks like I might have some funds to pull the trigger on a t4 turbo.
My build
E99 engine with 75k miles
Comp 910
Arp studs ( factory original head gaskets)
Casserly 250/100s
Dual sd pumps fed thru di fittings in the back of the head
-10an line tank to block
-6an return
5/8 pickup tube (dont even bring up a sump it wont work)
99.5 plenums with inserts
1 off t4 turbo mount and pipes
Here's the deal my truck is anything but a dyno queen or a race truck ... of anything its gonna be a driver show truck
I was leaning twords a s367.7 fmw but the s366 is much cheaper. What an I gaining with the 367.7 and what housings would you run?
Also I forgot to mention the truck has a manual trans and 410 srw rear
Sent from my SGH-M919 using Xparent Green Tapatalk 2
My build
Comp 910
Casserly 250/100s
-6an return
