jtpappy
Currently my truck has the following
Rcd 72/59 chargers
30% injectors
Airdog II
No limit goodies
Gear head tunes on mini maxx
New short block
Oring heads
Arp studs
Rcd push rods
46mm wastegate
Built mpd trans
It's been a fun truck on a street tune (performance doesn't hold rp) but I am looking for more!!
I just picked up a duel fueler, and I built a custom lpfs
-a1000, cat filters, aeromotive regulator, sump
I plan on running the feed lines straight to the pumps after a Y-block.
I am putting them on when the pump shows up. But I have a few questions
What rp should I run now?
What psi should the regulator be set too?
What psi can I see the wastegate to? (Stock valve springs, unless Morgan can hook a brotha up)
I am I okay on stock pistons?
Thanks guys!
Rcd 72/59 chargers
30% injectors
Airdog II
No limit goodies
New short block
Oring heads
Arp studs
Rcd push rods
46mm wastegate
Built mpd trans
Thanks guys!
