Duel fuel, 30s, and 72
jtpappy
Southern Maryland
Currently my truck has the following
Rcd 72/59 chargers
30% injectors
Airdog II
No limit goodies
Gear head tunes on mini maxx
New short block
Oring heads
Arp studs
Rcd push rods
46mm wastegate
Built mpd trans
It's been a fun truck on a street tune (performance doesn't hold rp) but I am looking for more!!
I just picked up a duel fueler, and I built a custom lpfs
-a1000, cat filters, aeromotive regulator, sump
I plan on running the feed lines straight to the pumps after a Y-block.
I am putting them on when the pump shows up. But I have a few questions
What rp should I run now?
What psi should the regulator be set too?
What psi can I see the wastegate to? (Stock valve springs, unless Morgan can hook a brotha up)
I am I okay on stock pistons?
Thanks guys!
i wouldnt want to see over 65psi ebp on the mini maxx esp with stock springs. you are never safe with stock pistons in a 6.4
bft blue oval boys
Burlington, NC
Good decision swapping out ya'lls tires! I believe you will want it set to 15ish psi on the low pressure system. RP should still be 25k ish I think. Pretty sure the k16's kinda regulate themselves so to speak
johnp115
Southern MD/Charlotte NC
One stock pump pushes 20-25k on a big tune so multiply that by two and give or take 5k for each pump so I'd say somewhere between 40-50k rp on a full tune..
bft blue oval boys
Burlington, NC
STFU & GTFO with that crap lol. His injectors and rails would explode with that much pressure. I'm sure you're joking though....
Dual pumps increase volume to maintain pressure, not higher pressure.
johnp115
Please don't take me that seriously lol.
But ya, more extensive custom tuning and fuel flow monitoring / temps but still 25k at most.(commanded through tuning) So on 30's both pumps won't be streesed near as much as a single pump on stock nozzles.
bft blue oval boys
Burlington, NC
Sheww, I was a little nervous there for a second lol. Started to sound like a Cummings guy....
San Antonio Tx
Go and run 15-16psi of fuel pressure from the low pressure side.. The high pressure is like 24-26k. Wastegate should be set around 68.. Would highly recommend springs and all that crap.. LOL
Also if you're gonna rip it apart throw some pistons so you'll never worry about it again.. Also make sure to if you can put a good used hpfp in the valley so if the seal gives out at least it will be on the outside hpfp.. Also have fun!!!
jtpappy
Southern Maryland
Thank you! Hopefully Morgan can PM me about some springs and instructions to do it heads on.
cool looking truck.
Thank you
Your rail pressure should hold at whatever the tuner has the desired rail pressure set at.
I mess up! What pw should I run!!
Working on the springs. The motor ain't coming apart lol. Cab on, pulling turbos and trans if I can find some 6.0 manifold to 6.4 uppipes quick and cheap. For the 6.0 manifolds in the garage.
B585Ford
WV
Exactly :whs:
If you want the most performance a PW of 2.3 or so tune.
....true-but multiply the chance of pump failure by 2 :)
Stroked777
Casper, Wyoming
I was talking to tommy hassler when we was in pine grove pa at a dyno and he said he runs 50k in his puller. It's a 7.3 with a 6.4 injection system, dual pumps
bft blue oval boys
Burlington, NC
If that's the same one I think you're talking about I'm pretty sure he said that it spiked that high... He has also replaced rails and injectors because of that. There is no possible way stock injection systems could handle that much pressure, not for long at least. They weren't made for it.
I mean I could be wrong but get him up here to tell me haha
