TrailerHauler
Yeah, you shim to achieve desired seat pressure, relative to installed height.
And I'd bet attention to properly gating boost/BP would go a long way.
Aggie's block and heads were bone stock at 300k correct? No way those valve seats were in the shape required to get away with non shimmed springs.
Height of the spring from the seat to the top of the spring right?
And yes, both chargers were properly gated and yielded very reasonable backpressure numbers from what I can remember. But I'm not sure at what mileage the truck was first modified. I do know that he had over 400k on the truck when it came apart for the 12v and it still ran good as far as I know, which I thought was rather impressive.
