My Rolled and Rebuilt 6.4
one2nine
Altoona, Pa
Does anyone on her have a 4.5 lift with 20x12s? I'm curious now. So the 3m clear bra stuff holds up ok? The fuel mavericks have been catching my eye. Been thinking about doing those on 37s and running my ions with nitto 420s as a street setup
nickg3130
West Long Branch, NJ
Well, do to a misunderstanding my order never went through on the 3.5" lift. So should I go 3.5 or 4.5? It will be ordered by the end of the day.
TripleE44
Keller, TX
If you're on the fence and one of your concerns is clearance, I would just go with the 4.5. It's not gonna be a whole lot taller, but you're gonna be unhappy if you end up rubbing still.
PS. My 3.5'' finally goes on today. :clapping:
nickg3130
If you could, send pics to me at 732-859-0969. That would be awesome.
SEABEE08FX4
Montgomery TX
3.5 is plenty of clearance for a 12 wide wheel, its the tire size thats going to cause a issue. I'm running a 2.5" and 22x12 and 325/50 tires and it rubs a little bit, a little triming or a heat gun and reshaping of the fender liner will be needed.
powerstrokin15
Charleston, WV
hes running 20x12 and 35/13s now with a 2.5" but he had to space his bumper, and will most likely rub the fender offroad... so he's going up.
Sent while charging my POS iPhone 5 battery
SEABEE08FX4
Montgomery TX
That would be from the angle the radius arm is at, PMF and Ready Lift both have 3.5" radius arm drop brackets that would correct that issue.
nickg3130
That's what I'm thinking. Im looking at a few 4-link kits to help that as well as add some performance. I already have pmfs 3-link but I haven't got the time to adjust it. I think the 4-link would be more sufficient but maybe I'm just crazy.
powerstrokin15
Charleston, WV
mine clears the bumper.. would a drop bracket or 4 link help me clear my fender some? if not I'm taking a sawzall to my inner fender
