cknox121's slow build
Athens, IL
I've got all the stuff you should need. Be glad to discuss options.
There is still a good amount of the a-1's left if you want them. Although I don't know how much longer they will last. But they will no-longer be making anymore. At least until someone buys them out and starts producing them again.
On a side note I have no complaints using arp's and the price is cheaper.
Check out the website www.midwestdieselauto.com
Cknox121
Augusta GA
What makes them better then ARP? What's the torque required on them?
Crack85
Midland, Tx
I wouldn't say one is better than the other, it's really preference, Craig runs ARPs in King Kong n webb06 had custom aged n now has ARPs. Tensile strength is what your paying for.
StockCar#10
cheyenne,wyoming
Not to derail but why arent they making arps anymore???
Cknox121
Augusta GA
Arp 2000's and a-1 1722's are the same tensile strength.
H-11 and custom age 625 are the higher tensile.
Thanks for the info.
Goal for this truck is a reliable DD, with possible higher hp mods down the road!
Know where I can get a ford tech book for the 6.4?
Athens, IL
So what about pistons? Delipped? Advantages of valve reliefs?
Pistons, if you dot want them to crack and ruin a cylinder wall the de-lipping is a must. Coating also helps with heat and cracking issue. The valve reliefs help you from having piston to valve contact should you have a problem like valve float.
Aside from that there is no performance gains, all for reliability and keeping it from having bottom end issues.
Cknox121
Augusta GA
Thanks.
I'm in a shooting tournament rest of the week. Be expecting a call from me Monday of next week.
