LED Headlights and Fog Lights
CT9AIX
MA
Well, got'em installed. Just need some darkness now! They're bright as balls durring the day, so I can only imagine what they are gonna look like tonight
CT9AIX
MA
I got some pics last night with the regular bulbs, once I get some pics tonight with these i'll post them up
Demon
Alberta, Canada
Looks like I'll be getting 2 sets when you line up shipping for me. A friend wants In too.
Sent from my iPhone using Tapatalk 2
Demon
Alberta, Canada
No in your stock housings. They have a deflector built into the bulb housing.
Josh I would actually prefer if you would send the package via postal to me. I've brought enough parts over the border to know it will be far and away the cheapest for me. For duties and handling.
RSK
Connecticut
connect the driver box to the actual bulb which is super easy and only fits one way, then plug the driver box into existing wiring harness and twist bulb into factory housing and apply double sided tape to location of your choice to mount the drive box, and install the 4 bolts to re attach headlight housings and one side is done, repeat for the other side and enjoy your new lights.
stock head lights.
Led head lights only.
that's a little over 100' away with both the rigid dually led fog lights on and the led head lights on...
head lights
both
overall they are bright, and match the fog lights very well, much better then the stock head lights.
GatorBaitR6
Gray, TN
Wow makes me sad that I just bought new bulbs for my hid kit for my 08 front end swap... someone Wanna buy some 6ks lol.. thanks for the pics nice job..
CT9AIX
MA
they're bright that's for sure. I forgot to take some pics last night... I was too busy working on giving my self a headache for this morning lol
GatorBaitR6
Gray, TN
How much for fog lights... Nvm I see it takes takes a conversion can't delete on the app so I'm just editing...
South Florida
Fog lights have a few options.
1. Rigid Dually/D2 Conversion
2. H10 LED Bulbs that are the same style as the Headlight Bulbs. Out of stock for 30 days.
3. H10 Plasma LED bulbs. These are cheaper than the above option, still a great light that will match the color output of the LED headlights. $90
im really liking this option more and more i see about it.
Hows the reliability of the module that comes with it? That was always the biggest issue with my HIDs was the start up of the ballast when its cold.
South Florida
Well HID require a lot of voltage to start and get the ballast going. LED as we know draws next to nothing so I think these "ballast" are just regulating voltage. Should be much less of an issue.
RSK
Connecticut
they work down to -40 the box that comes with them is an led driver. they use almost no power. 28w each maybe? the only thing i noticed that was different was when you turn the high beams on its not much brighter, but the low beams are already 2200 lumen, and when i turn my fog lights on it extremely bright so there is no need for a high beam really.
CT9AIX
MA
I noticed the same thing, which i'm fine with. just used to the crappy halogen low beam so there was actually a difference when the high beam got put on. now the low beam is so bright the high's don't do much
Demon
Alberta, Canada
Josh did you get a chance to email shipping to me for Canada?
I just got a message from my provider that said there was a disruption in my service. So I might not have received it.
