Powerstroked
Ok so I know this thread seems like it is just another 6.no-start. My situation is a strange one. So about a week ago the truck started showing signs of hard start and it was a bit sluggish...not to much though. The hard start issue turned into a no start when hot issue, and then it was even hard to start cold. Having removed or replaced what I thought to be all the known 6.0 problem areas. I tackled the one thing that makes sense that I hadn't changed, the dummy plugs and standpipes. While I was changing them I charged the batteries to prepare for extended start time. I will have to say after I put everything together the restart was easier than normal (I have replaced injectors and it took awhile to start). I took it for an extended drive and it ran great! So why am I posting then right, well "I" shut it off and it will not start up again. I put the charger on the batteries and they are low, the truck turns over without hesitation though. What possibly could be causing something like this, it won't even start cold now!
