cknox121's slow build
Cknox121
Augusta GA
Think this will hold?
Save some cash I'm going to take motor all they way apart, and take block, cam, crank, and heads to shop and let them do there thing. Then assemble at the house
Motostroker
Personally I would let a machine shop build the short block. That way if you mess up you won't ruin anything.
Will@Rudy'sDiesel
Burlington, NC
Fine dammit. I'm taking it apart then taking it to him tomorrow.
Sent from my cracked iPhone using Tapatalk
I know you wanna do it yourself but if he messes something up then it's not on you!! Quit being so freaking hard headed, take it to him I will come down and we will have a liquor drink while he builds it!! :pint:
3brorce
Contact Josh and Ricky at Darkhorse they will shoot you in the right direction.
Cknox121
Augusta GA
Dropped the motor off at the machine shop this morning.
Upgraded with the following-
international HD pistons with coating
New bearings
Balanced rotating assembly
Ringed heads
Upgraded springs
Valve job
They are also installing the ARP's and new gaskets.
Front and rear cover and fly wheel.
I'm still contemplating getting the heads ported and polished.
Edit: going to add a 59mm high pressure turbo along with the 71mm atmo. Fuels staying stock. Stock exhaust manifolds with hd up pipes.
While the motors out I'm going to pressure wash the frame and trans. It's pretty nasty and oily so figured would be a good time to do this.
Cknox121
Augusta GA
Also on the list will be
Hd up pipes
Maybe a air dog
No limit intake
Possibly some fuel
Waste gate
