New Toy
DocBar
Akron, Ohio
I just bought an 01 F350. 318,xxx miles, new Jasper trans, lights galore, Road Armor bumper w/winch, one stupid stack, CAI, and the rest of the drive train is stock. It's also lifted w/ Niito Dune Grappler 315/60/R18 on Rockstar rims.
Planned future mods are RR fuel system, HBJr, Brute66 and definitely ditching that stupid stack. I'm going to talk with Dynoproven and ******** about hybrid injectors. Wanna keep it alive, but add a bit of power. What injectors do you guys think would be good for ~400-450 RWHP?
Kyles%20truck%201_zpsqdl1wtiw.jpg.html
Kyles%20truck%202_zpsqlpnuohu.jpg.html
Stupid%20stack_zpsoajxpryw.jpg.html
psduser1
on the road
200ish/200%, and plenty of oil. Be right there.
Unless you really want 550ish, then go hybrid, lol.
DocBar
Akron, Ohio
The injectors will be hybrids. Not looking for over 450 rwhp. Trying for reliability with a bit of fun to accent the visual mods of the truck. Not looking to replicate my '03. This is for a 20 yr old kid with a baby due in a few weeks.
He needs to get back and forth to work. I just want to make that trip a bit more fun.
then leave it stock and reliable so he actually makes it to and from work.
DocBar
Akron, Ohio
Update and need some answers. The truck has a bad vibration, felt in the seat, when accelerating fairly hard (like getting on the interstate) and I feel mild vibrations when coasting or cruising above 45 mph. I've replaced the u-joints and carrier bearing and had a shim kit put on the carrier bearing to get a better pinon angle, due to the 4" lift. No idea what brand the lift is. The vibration has gotten worse. There is also a slight "howling" sound when cruising that isn't tire noise. Any ideas before I start throwing money at it?
Jomax
Arizona
Rear end is taking a dump? Does it do it only when you put a load on it? Does it stop when you put it in neutral?
DocBar
Akron, Ohio
Haven't tried it in neutral. It vibrates strongly when putting a load on it, but also has mild vibration just cruising above 45 mph.
Jomax
Arizona
Rear ends usually howl when going out.
DocBar
Akron, Ohio
Ended up being the transmission. Got a new one, under warranty from Jasper.
Got a few wear and tear components to replace, but other than that, the truck seems to be doing fine. The motor seems strong.
