question about my dad's 6.0
6.0stroker
Last weekend we put a wicked wheel in his stock turbo and mbrp 4" exhaust and now is puffing blue some even wen warm, the truck is 60,000 org. Miles never ever had a problem w his truck and it's running just fine and no lights on I'm wondering if maybe seals in turbo went?
6.0stroker
The hot side pipe correct?, and if their is oil in their then the seals in the turbo are bad and if they are do they sell a seal kit for those turbos?
swinky
Eastern, Nc
Yes yes and yes. Unless the truck has so much blowby that it's smoking at idle, very doubtful.
My 366 is leaking right now....
6.0stroker
He said it's smoking wen he's at a stop light and the longer he sits the .ore blue smoke their is
webb06
Seneca, MO
Did you remove the shaft from the turbo when you put the new wheel on? If so that's probably what caused the seals to start leaking
6.0stroker
Should we rebuild the turbo or put new seals in the turbo?
