Remote oil filter kits
Extended Power
I'm trying to add a A/W intercooler off the secondary...need to find room.
Not sure if I should sell all the piping and start over, or hack up the stuff I got already.
.....winter project.
motoxracer42
no point in air to water unless its a drag truck. don't waste your time or money. to get an air to water built by someone that knows what there doing lol, and can hold up to our boost is around $3000. all the ones you see online will burst.
ivan I think your thinking too hard hahaha
motoxracer42
I just realized I asked mike at mdp to send me a plate lol,. thought it was steve.
looks good mike. I like it.
Extended Power
I just want to try and make the intake temperature a lot cooler than it is on a 97*F day like today.......without nitrous, or water meth.
There has to be ways to make the charge air cooler...I have some ideas, but never enough money.
Skinny
British Columbia, Canada
Made our own kit
Sent from my iPone sitting on the crappe
09stroker
Texas
I don't think the air/water would be a waste. If that's the case then why did ford add a air/water on the 6.7?
They use an air to water IC instead of an air to air IC because its packaged much smaller. It's not a water to water cooled with ice.... It still can only cool down to ambient at the most.
Skinny
what size are those lines? looks a little on the small side. I run -12 on mine
Ill find out I can't remember i have about 3 months so far on the set up no issues so far... The filter I'm using is a elf7349 Donaldson
Edit: looked at my build thread it is -12
Sent from my iPone sitting on the crapper
