If a belt is available that is just 'slightly' shorter, you can wind up the tensioner more and put it in the higher rate of the spring and 'maybe' keep it from slipping. But, we don't usually offer belts in those longer lengths that close together. I'll cross a couple fingers for ya..
Timbo made a comment about nobody in the thread making an accurate statement on the topic of A's vs B's vs Hybrids, and something about he and his keep innovating so on and so forth, as if everyone else is lost. We also hear a lot of heat about how larger nozzles don't make sense on the street, don't work as well as little ones, yada, yada, yada.
This would lead a person to think he has gobs of power on tap with clean driving. So.... since I don't keep up with the 7.3 stuff much anymore, what have you done man? Are you like 7 or 8 hundo on fuel with your 30's or 100's or whatever ratio is so awesome or what?
Because the apparently misleading and inaccurate statements being given in this thread are coming from the guys running setups akin to what Mike-O did over 600 on fuel with after passing the Colorado emissions test!
That truck was so close in setup to my daily driver it's not even funny. Which is probably why I also don't get the small nozzle logic, as my truck drives like that as well.
I guess at some point I would need to see the pudding that supports your "weight" in a conversation where you contradict logic that has done the deed. As in, not hypothetical.
Are you hypothetical, or have you actually done something I guess is my question?
The guys injectors are ***king awesome but I dont really know how much hotrodding he does. Ive got very limited mileage on my truck since putting his 250/200s in yet they are way smoother and responsive than the previous set I had if the same size.
I know you have that's why I asked which ones they were better than. If they completely blow my swamps injectors out of the water as he seems to suggest, I'd be interested.Ive ran other injectors lol.
Swamps were good too. No complaints.
I figured, that's why I said I had not personally seen them. All I see is his bashing all other injector builders out there. I just wish he would cite a little more evidence when he brings that argument up, otherwise he just sounds arrogant after a while and people like me sound like a jackass when it's brought up..And there have been dyno results posted by people. Pis has posted dyno graphs before, fyi.
We can be jackasses together lol :toast:I kind of agree with cbf9703. Not to knock pis. I've yet to hear a bad thing about his injectors, BUT he does seem to give off the vibe his injectors are better than every other company out there. Unless he is onto some pixie dust **** none of the other dynasty 7.3 people know of. Hell, maybe he is, and I'm a jackass... lol
idk what he (Tim) does but they are some smooth runnin injectors. Swamps and FF are pretty close to where my parents live, Rosewood is about an hr away from where I live and I'll still only buy from Tim.
i haven't read a thread yet where tim is bashing anyones injectors.. he simply states thst his comparatively inject more fuel... i dont run any PIS item either. im just goin off what i have read.. basically i will have PIS injectors when i upgrade whitey though... thats how much i have read up on all the injectors out there...I know you have that's why I asked which ones they were better than. If they completely blow my swamps injectors out of the water as he seems to suggest, I'd be interested.
unless hrt releases his own design and i go to an open pullijg class... lol
live life full throttle
It is not hard at all to get one apart, no real accomplishment there. But setting one up to do what you want and matching 8 together, that sir is another story. And by what I have seen over the years from some of these "top" shops is sad. If only people could see what their injectors really do and how corners were cut in the name of profit margins. :lame:
And the A code, B code, hybrid argument is funning. Not one person that has as much flow bench time as myself has come in and made an accurate statement. But you guys serve up the Kool-Aid and the rest keep drinking so keep it pouring and we will keep making advancements.
We have had more people happier with our 160/30's than anything close to it "size wise" on the market. For that point we have actually seen our 160/30's outflow some 160/100's on the bench before. Depends on what you buy and from whom you buy it.
Some people/builders still only believe there is nothing more to injectors than cut pistons and different sized nozzles....................:doh:
People still believe injectors are just cut pistons and larger nozzles, :shrug:
The old saying used to be you get what you pay for. Now its you are paying for what you are not getting.
