opening the gate will help it drive harder but in the end its only going to drive so hard based on turbine size and gating.
you really need to be carefull with gating off of one side, im betting that back pressure is way higher on one side then on the other. thats what i kept running into on mine. I actually have my gate held shut with boost right now, runs better than it ever has been and back pressure is in check on both banks.
just something to consider before you get much further, i actually figured it out because i kept blowing bolts out of the left side uppipe after about 3 passes at the track
