Any of you with schemes involving pressure to the bottom of the gate being necessary to open the valve, you will lose control if you blow, rupture or in any way kill that line. Ask me how I know...
For this reason I recommend using a 4 port solenoid with a super light spring and shifting from full boost to the top port when below your desired boost, to then having some smaller amount of boost to the bottom port as the solenoid shifts the spool, automatically sending the top port to exhaust and bottom port to pressure. This is fail safe, in that losing the top line immediately makes the truck a dog around town. Losing the top line at full song changes absolutely nothing. When you come back down off of power the truck is a dog. Losing the bottom line means your boost will creep on you. Something you can see and the total creep won't be much if your spring is sized soft enough. The little bit of creep potential is worth the snappy response off a shift with full boost swinging from bottom to top, back to bottom again. Loads of valve control with this scheme.
In contrast.... if you run full boost to the bottom port, then regulate pressure to the top port and you blow that reference line to the bottom port get ready for stratospheric boost with compounds... It will jump so fast and so high that the motor is probably already hurt before you notice, unless you're spinning the wee out of small chargers that won't go stupid if left to their own devices.
If you don't have an electronic boost control, which is likely, then simply set the spring soft enough that with no lines connected to the gate the truck will undershoot your desired boost a bit. Then run regulated air to the top port and simply vent the bottom port to hit your target boost. This way it is failSAFE, in that a blown line means the truck lays over and boost returns to the sub-par number you set on spring only... The downside being that it will be a bit softer on shifts to hit back to desired boost. But not by much.
Words from someone who's lifted heads with a blown signal line as configured in a way that relied on a full manifold signal to the bottom port.
On Edit:
Besides... the damn things are much easier to assemble without all the cock diesel springs in them...
