help?
Diesel23
NWI
On side of the road , was driving and just lost power , it shows check engine light on won't turn over , let it sit a minute got it to start then shut off right away ? Any ideas cam shaft positioning sensor ?
wildbillcody97
Seaford, De
Crawl under the center of the truck its by the harmonic balancer. Ford pn F7TZ-12K073-B
Sent from my DROID RAZR HD using Tapatalk
Diesel23
NWI
Thank you man , i drained fuel filter and it started and is driving but now it shows ABS light is on ?
zilla68
Moore Oklahoma
10 mm wrench I believe it is.
if you are looking up at the harmonic balancer its just to the left and above I believe.
ToMang07
Mainah!
*knocks on wood*
I was actually laughing last night, I went through my truck, I have 4 spare CPS's, lol, one BW, 2 OEM Black, and an OEM Gray.
Best part is I took the 10mm socket wrench out to use it the other day...and never put it back. So *IF* I have one fail.... I can't even put one of the 4 spares in, LOL
:lookaround:
*knocks on wood*
:lookaround:
are the black ones the original black ones that came in the trucks from the factory?
Diesel23
NWI
did you replace cps?
No not yet , i drained fuel from fuel bowl and it started up, no check engine light but shows ABS LIGHT. Will the cps cause low voltage enough to through abs light ?
I made it home Will change cps sensor and fuel filter
Diesel23
NWI
*knocks on wood*
:lookaround:
I had 2 in my glove box !!! my help that was with me detailed truck about 2 weeks ago and she said Oh those sensors yeah there in your garage !!! Lol !!
