First Annual Maryland Performance Drag/Dyno Event
Bobby@MPD
We need to start getting a head count on who wants to dyno and what times you guys would like to start. The gates open at 10 and the dyno should be setup by then
03mm
FL/MD
I will hopefully getting on the dyno and time don't matter I'll probly be there all day.
Ad8 PRODIGY
Orange County, NY
Get there early then... Duh
How about you be kind and just put my name on the list :poke:
I should be there plenty early though. Staying friday n saturday night at the hotel. Oh and i couldnt talk Jim into coming this time... still doing a sakuras trip like last time though
Gmoney69
Ok thanks mike, if Matt ever straightens out my mcc tunes I'll try n get up there...
Bobby@MPD
Gates will be open at 10am. The dyno should be setup by then and we are going to try and have you guys immediately start dynoing. There will be two tech stations one for drag racing and one as you enter onto the dyno. The one at the dyno only be there to make sure the truck is competing in the right class(s). The tech for drag racing is to make sure the truck is safe to run at the track, the track follows IHRA rules. If you plan on drag racing, I would go through the safety tech line first since it may take longer than head over to the dyno, also pending on the amount of trucks we will probably have a time request sheet setup to maintain order.
Bobby@MPD
We will always be having a 50/50 raffle, as well as raffling off a brand new set of Fuel lethal 20x12. We will also have stickers & event shirts.
