h2e kit
blackcloudpsd03
There's also of different kits out there who has the beat quality that wont leak?
When running a t4 kit what kit of mods do you have to do? Bigger plenums? E fuel?? Can you run a t4 kit with the factory fuel bowl and pump? Do the kits come with all the boots and clamps down pipe?
blackcloudpsd03
I Dont have big fuel. Just stage ones. And I planned on doing the 19cm housing. I had a 6.0 I can keep egts in check.lmao.
blackcloudpsd03
Something like that.
old man dave
Petaluma, CA
With a H2e, shouldn't you be looking for a T4i kt?
gnxtc2
Bergen County, NJ USA
Correct the H2E is a T4i. I would do a T4 over a T4i. There much more turbo choices with a T4.
You need to have E-fuel. The bowl and fuel pump are in the way. Plus, most kits use the fuel pump hole as the turbo oil drain.
No you don't need plenums but you are going to need to use reducing couplings (2"-->3").
I have an Irate T4 kit with no complaints. The kit came with everything needed.
Billy T.
[email protected]
OBSWIZ
Wellington NV
We have a kit with Bellowed uppipes, mandrel bent IC pipes and unlike the Hypermax kit the oil lines will not leak.
PM me if I can help.
blackcloudpsd03
Another option I just found .. Is a diy kit..how is the barders diy 66/94and ported housing all I have are stg1's I know his 6.0 stuff is great
bruce
Middle east
Hell for those injectors I'd spend that money on a ww2, 1.0 exhaust housing, intercooler set up and e-fuel.
CSIPSD
Bend, OR
Yup... Much as I love my H2e... For that injector just stick with the stock turbo.
blackcloudpsd03
I'm at sea level I live in south fl. Not many hills down here. I Dont mind the larger housing I do have 4:10s it should help a little. Thank you for the input. Are there any reviews on the diy kit or videos it sounds dumb but I miss the whislte I had a fmw64.5 and a 366 on my 6.0 I miss that sound lol
