Don't think rings are set
Magnum PD
VA
Got over 900 miles on rebuild and worried that I got too much blowby.
Will that set eventually or should I do something TO set them.
Magnum PD
VA
I've drove it with a trailer, up and down a pretty good hill with it loaded. Didn't baby it or over heat it. Turbo blew doing that though. That shouldn't have anything to do with the rings right? I did do a hot retorque with it on the stand. I varied the rpm's doing that. So not sure if I did something wrong.
Magnum PD
VA
Can't get videos to work on photo bucket.
I could text the video to another member of someone wanted to try it.
ghohouston
Lewisville,Texas
What exactly failed on the turbo? I suppose if compressor wheel shattered, or anything metal on the intake side broke, small pieces could have been ingested into a cylinder.
Magnum PD
VA
The compressor wheel had "some" material taken off but turbine wheel is what broke off from shaft. Then oil went out exhaust.
jimdawg185
What oil did you use for break in. I know our oil will not lets rings seat. I'm sure others might do that as well.
Magnum PD
VA
I used cheap oil for the startup and hot retorque. Then put in Mystic 15W40 oil. Blend of synthetic.
It's not bad. I started it up, cold. plugged the vent hose and turn oil cap over and not much air when I did then.
Arisley
Arlington, Texas
Throw some cheap Rotella in there and run it for a 1000 miles or so. You gotts be a little mean to a motor when it's new. Let it know who is the boss.
Magnum PD
VA
WHO'S YOUR DADDY?!?!?
I can do the rotella if that's what yall think can help.
Arisley
Arlington, Texas
Use a good oil filter though. Those rings have to cut their way into a perfect fit with the cylinder wall (that's what seating the rings is). After a 1000 miles, if the rings are set, change to what it will live with. If not, repeat. I would probably not really use Rotella though, maybe Delo, just use a dino oil.
