fords4life
Greeley, CO
XED57385
Just thought about it after I posted....that won't matter because I have a '99. What are the options that need to be confirmed?
Extended Power
these parts are for a king ranch version with the beige.
3C3Z-99291A40-BAA list $112.77 sell $81.19
3C3Z-99291A41-BAA list $112.10 sell $80.71
3C3Z-9940602-AAA list $81.17 sell $58.44
1C3Z-17626-AAB list $157.40 sell $113.33
shipping $25
q#376127
Is this quote still legit, or do I need another one from you?
strokinpower
Greensboro, NC
I'm curious to see what the price is for the 6.7 powerstroke door emblems that come on the new 2016 F650's and 750's and to see if you have a pic of one.
04 6.0
Cylinder head
Head gaskets
Front cover gasket
Rod bearings
Lifters
single piston kit
oil screen under oil cooler
oil cooler
sunrisefordparts
04 6.0
Cylinder head
Head gaskets
Front cover gasket
Rod bearings
Lifters
single piston kit
oil cooler
Cylinder head list $1551.78 sell $1117.28 w/exchange (core $250) each
Head gaskets list $197.94 each sell 154.39 each
Front cover gasket list $55.54 sell $43.32
Rod bearings list $30.08 each sell $22.74 each x8
Lifters list $77.86 each sell $55.90 each x4
single piston kit list $161.25 sell $116.10
piston rings list $77.63 sell $55.90
oil screen under oil cooler list $22.89 sell $12.36
oil cooler list $439.83. sell $316.68
q#401160
shipping on head $50
Tom S
Think, I have to do a valve job on a 2003 Taurus OHV Flex VIN 1FAFP55283A237305
I need to start lining out the following part plus anything else I missed for the job. If you could please put in part numbers that helps in the event I just order off the site instead of calling in to pay the qoute.
Valve grind gasket set or what ever has all the gaskets for the job
Head bolts for both sides if they are separate
Rear Manifold to Y pipe gasket which I think is 2F1Z-5F263-BA
Updated heads
Thank you
Tom
matt92idi
Maryland
I got a 2004 f250 6.0 I need the following for
turbo exhaust clamps (both y pipe and down pipe)
intercooler boots and clamps
thermostat
Water pump
heater core
degas bottle,
low pressure ac line (the one you have to have the special tool to remove,) MAF sensor
Vgt pigtail
Eot pigtail
Engine oil pressure pigtail
Fuel return line
Serpentine belt
Thanks
Matt
sunrisefordparts
thermostat
Water pump
heater core
degas bottle,
Vgt pigtail
Eot pigtail
Fuel return line
Serpentine belt
Thanks
Matt
which return line are you looking for?
sunrisefordparts
Updated heads
Thank you
Tom
valve grind kit 2f1z6079ab list $81.98 sell $59.03 (only comes with head gaskets, exhaust gaskets and tstat gasket)
intake set f6dz9433a list $50.45 sell $36.32
head bolts f8dz6065aa list $4.58 each sell $3.30 each x16
exhaust seal 2f1z5f263ba list $11.08 sell $7.98
heads 6u7z6049a list $477.45 each sell $372.41 each w/exchange (core $150 each)
q#401358
