Traction Bars? Lets see them.
Layson
I put the short gussets on my Dads setup on a stock height truck... All bolt on right in the driveway.
dsmracing1
Alberta, Canada
I run the OUO short gusset bars and love em! Makes shifting so much nicer and it completes to the truck to make it feel how it should be in the first place...
ImageUploadedByTapatalk1455045504.186001.jpgImageUploadedByTapatalk1455045522.224262.jpg
WHY NOT
Carlyle IL
ptm'd OUO long gusset bars and ALA's :toast: Jared, aka breaking habits on here will hook you up with what ever you need
c63 AMG
Whats difference in short vs long other than length?
Sent from my banana using Tapatalk
Breaking Habits
Mapleton, Illinois
No difference in length whatsoever.
The difference is in the gusset on the botttom of the bar. The short gusset is low profile, as the long gusset has the logo and other gusseting on it, and is a little bit flashier
Difference is in aesthetics only. Both are extremely strong.
Just done for guys who want a different look.
Anymore I just run short gussets unless the truck is up in the air some, then the long gussets look awesome
c63 AMG
Thanks that makes sense.
UNBROKEN
Any good bit will punch right through. If you start small and work up in 2-3 steps it's really not a big deal.
So which brand is better? Pmf or ouo. Pmf looks good and is better priced
I've seen OUO NOT limit the true way the axle is suppose to work. From FULL droop to FULL compression.
Until any other company can prove that. I personally will stick with OUO.
