Layson
- Joined
- May 18, 2011
- Messages
- 1,638
- Reaction score
- 0
I put the short gussets on my Dads setup on a stock height truck... All bolt on right in the driveway.
Whats difference in short vs long other than length?
Sent from my banana using Tapatalk
No difference in length whatsoever.
The difference is in the gusset on the botttom of the bar. The short gusset is low profile, as the long gusset has the logo and other gusseting on it, and is a little bit flashier
Difference is in aesthetics only. Both are extremely strong.
Just done for guys who want a different look.
Anymore I just run short gussets unless the truck is up in the air some, then the long gussets look awesome
What are you guys running for traction bars? Got pics?
Any good bit will punch right through. If you start small and work up in 2-3 steps it's really not a big deal.
What did you guys use to drill thru the frame? Suggestions on bits or is there another route to use?
So which brand is better? Pmf or ouo. Pmf looks good and is better priced
