Need advice.... Swamps T4i S366 and Hypermax to S369 SXE
nossliw
I’m back with another question. This one is a first for me.
I’ll keep this short. Friend bought an Excursion with a handful of issues. Needless to say the turbo went as well. It was advertised with an Irate t4 kit installed with a gen 1 366… or so we were told from the PO. Turns out it is a t4i kit from Hypermax. After researching the tag number the turbo is a hybrid 366 from swamps using a T4I housing in 1.15 trim to work with the Hypermax kit.
Not knowing any of this while we ordered a new SXE 369 from Barder turbo, we now have a fitment issue. Milling the flange to accept the t4i pattern on the 1.0 t4 housing would not be difficult, but does not help us out. As those who have been in this situation, it’s the fact that the t4 mts about 3” higher than at t4i kits from Hypermax. Therefore nothing will fit up with the turbo that deep in the valley. An adapter plate can be found, but is also not an option due to the vertical change needed and likely pushing the housing into the y pipe. He is not going to rip out the Hypermax setup and pay to build a t4 kit, as the Hypermax kit was a one off to accept the aeroforce sensors/pyro/etc. He would also like to retain the 369 rather than going to a holeset setup due to injector size and purpose behind the truck.
We ordered a 1.00 housing on the 369. Injectors are PIS 238/100S. The Excursion will be used as a DD and towing a 15k travel trailer quite frequently. Heat is his main concern towing over the CO passes. Truck will reside in a stock or mild 40-tow tune when pulling.
So after taking a closer look at the old 1.15 housing and trying to fit it up to the 366, it would be accepted by the new 369 center cartridge, as its near if not identical to the 366 from a visual. However the old 366 had a 74mm turbine vs. the 80 that’s on the new 369. So besides that issue it’s a direct fit.
Until I can find a vendor that has released a t4i housing that will accept the Hypermax setup. My question to you all is why can’t the interior of the exhaust housing be milled to accept the 80mm turbine? When comparing to the current t4 housing it looks like that is exactly what BW did to fit the bigger wheel in there on an unchanged t4 housing. I compared it to my 366 and the exhaust side is the same, but slightly milled.
My first option would be to hear or find a vendor who can supply the proper housing.
The second is to take the current 1.15 housing off the old unit and open the inner bore on the exhaust side all of 3mm to fit the 80mm turbine, as it appears this is exactly what BW did to their t4 housing.
If any of you have any data on why this would be a bad idea, please provide it. If anybody has a contact for the proper housing please PM me ASAP, we would like to run a 1.0….
In the end this brings me back to where did swamps get the 1.15 housing from to bolt up to the Hypermax setup. I will be calling them on Monday to hopefully find this out. Is this a standard H2E housing, can I just find one that accepts a 80mm turbine and utilizes the same CC mounting diameter at the 366/369.
Thanks!
Swaan
Thanks!
The turbine in both the 66 and 69sxe are the same size .
There both a 74/80 turbine
Your 369 sxe should be a direct swap into the 1.15 housing if you want to do that.
But it would be a laggy hot bitch.
Your only choice really is to swap out the crappy t4i up pipes to a t4 setup if you want to run the 1.00 housing on your 369 sxe.
You shoukd of done a little more resurch before purchasing.
On another note your 369 will work for those injectors but a 366 sxe with a .91 housing would be alot better in almost every way.
Bigger is not always bigger people...
Swaan
Just to be a little more clear .
Both turbine sizes in the 366 and 369 are the same size.
74mm exducer and 80mm inducer.
Sometimes people just say it's got a 80mm turbine or its got a 74mm turbine but there essentially the same turbine no matter how you slice it
Have you actually tryed to put that 369 center section into that 1.15 housing??? It should be a bolt in.
But I still wouldn't run that combination if he wants to stay cool and tow in the CO mountains.
swinky
Eastern, Nc
S369 is unclipped. It's not the same turbine.
Sent from my SM-N920P using Tapatalk
Swaan
It's the same size turbine.
Fits in the same housings .
Yes it's unclipped but same size.
There both 74/80 turbines .
nossliw
Appreciate the info. I agree with most of what was said.
Here is the link to what was in the truck from swamps... https://swampsdiesel.com/products/66mm-s300/
That being said it's not a 80x74, it's a 74xXX, not sure as the fins are melted on the exducer.
Originally the truck had significant boost leaks, ran like ****, ran hot, blown injector orings, weak pump and more... Once the boost leaks were fixed as well as a list of other issues it ran pretty well in a stock tune and much cooler.
We are addressing the pump, rings, and blown turbo now... I have ran a 366 with .91 on some small 160s over the last 40k, and this spooled as quick if not a bit quicker than my setup with all the issues...
Where did swamps get their housing? I can't imagine it was only produced with a 1.15??
Regarding the research, turbo was ordered prior to the truck arriving in the shop and removing the current unit... That was my fault.. Not an idiot, trying to find a solution is all. Surprised the housings are this limited is all. Not that it is important, but the kit was also mis advertised when bought...on this site...
Yes I have tried fitting them up, they don't fit. An 80 mm will not fit in the old 74mm housing.
I came to ask if we were to mill it out to accept the 80 are there any adverse affects.
You really think a 1.15 would be that laggy with 230/100s?
Swaan
Ok if it was a 74 on the inducer then it was probley a 65 on the exducer. That is a older turbine from borg warner. A box s366 has the 74/80 turbine not a 65/74. Swamps must of did a custom build on that turbo. The small turbine explains why it spooled so well.
You could bring your 1.15 housing and have it profiled and cut out to match the new 74/80 wheel but I'm afraid it's not going to perform as well as you'd like. It would be better with a .91 housing
1badpsd
lebanon,tn
The holsets are great turbos. I run a modded h2e 66/76/17 and I love how it runs other than towing 15-20k it'll get a little hot but I'm running 250/200's. And as far as the mounts go the Hypermax setup is the best fit and finish mount available, if it was t4 and bellowed up pipes nothing would compare. I have 3 trucks with Hypermax, 1 with Irate and the Hypermax fit better.
nossliw
Understood. I was a welder for many years, from structural, to race cages, to pharmaceutical grade process piping. The unit on the truck was done by an experienced tig welder. It fits very well. I have installed a few irate kits, and have built many configurations of my own. In other words, yes I agree and that is why it is staying.
Regarding the H2E. I have not used them at all. I have installed a few for others but that was it. I have been with BW and sometimes garret for everything we have put in the 7.3s. Nothing against it. I have very little experience with it though.
nossliw
Understood, Beans and barter did not have a housing that would work. I'm hoping swamps calls back with good news.
Swaan
My advise, because your dead set on using the t4i mount, bring back or exchange your 369 for a holset from barder. I'm sure he could work you some kinds deal. I've never used a holset but have always heard good reports. That would be your best bet .
joe d
monroe mi
All i know is my s366 with billet wheel and my 238/100 are a spooling machine. No experience with the 369. I build boost around 1300 in first and can cruise in second at 1100 and have like three pounds its a really fun street combo. Figured id throw that out there.
cjfarm111
I still have a brand new s366 with a billet wheel and 360
Thrust in the box. Maybe I should try it
Swaan
Weird , I had a billet s366 also . Was a compleat turd under 2000 rpm.
Out of curiosity thou, how do u cruise in second gear at 1100 rpm with a automatic wouldn't you be doing like 20 mph ??
joe d
monroe mi
Yes sir about 22 mph about 3 lbs of boost... See i have been told by others that the s366 was a turd also i have no issues with it maybe its injectors? Did tou also have 238/100 ?
Swaan
No I had 175/80 inj .
So your telling me and every one else who's reading this that your truck will make 3 pounds boost at 1100 rpm just loafing along at 22 mph .....................
You do realize there's like no load on the engine at all doing that.
And if that truly was the case you'd be making like 25 pounds boost just free reving your engine to 3000 rpm in your drive way..
Only way that would be at all posible is with a turbo half the size of that 366 ..... but then back pressure would be insane.
Sorry bud, but I'm just not buying it.
joe d
monroe mi
How do you up load vid to this site can you? i was raised a man is only worth his word and i bet you truck for truck 2-4lbs at least at 1100 - 1200 rpm in second gear. Around 22 mph.
Swaan
I haven't figured out how to upload vids either.lol
What are the specs on your s366. Is it just a box borg with an aftermarket compressor wheel installed??
