96 cranks no start
wolaver
96 f250 7.3 has a clicking sound from engine while turning over and glow plug relay whining loudly..truck has plenty of juice while cranking and sounds like it wants to start..was starting and running great but I let it sit a month while I got a new transmission and got it put in now wont start
Sent from my SM-G928V using Tapatalk
pdumont01
CT
What's the temp where you are at under 45?
Sent from my Nexus 6 using Tapatalk
wolaver
Still in the high 70s here don't even get down to 45 at night
pdumont01
CT
Is the fuel filter bowl full? Fuel pump could a crapped out
wolaver
I put a new glow plug relay in it and it's still making a whining sounds..idk about voltage it has all new battery cables and new batteries I've checked for loose connections but haven't found anything
Arisley
Arlington, Texas
Stick a volt meter on the big stud on the alternator. Have somebody crank the engine, look at volt meter while cranking. Tell us what the voltage reading is.
wolaver
I got a battery load tester charging system is at 14.2 volts little over 12v while cranking
pdumont01
CT
You have to hook up a scanner that can read the sensor values and monitor the ICP or injection control pressure. It has to see 500 psi when cranking to fire injectors. You could pull the hex plug off the top of the reservoir just to be sure oil is getting to the HP pump you should be able to see it not too far from the top.
Also make sure the engine oil level is good that would cause it not to start as well.
Is the tach moving up a few hundred rpms when cranking?
wolaver
What kind of scanner do I need? And yes tach moves
wolaver
Bad glowplugs? Checked resistance in them today and got around 2.5 on all of them
webb06
Seneca, MO
If you aren't getting white smoke your injectors either aren't getting oil to them or they are bypassing all the oil that is getting to them.
