B Codes, Not a Noob post
Hotrodtractor
Mingo, Ohio
* more powerful solenoid and spring allow for significantly higher icp
*.lower ratio barrel to plunger to decreaser oil vol needs
* oil passage poppet changes to minimize pressure drop across the injector.
* larger nozzle for increased durability
I can't seem to locate any of my pictures of my custom solenoids.... if someone wants to dig I posted a couple of pictures somewhere (maybe PSN) several years ago.
West Virginia
Drool... that is awesome stuff. I'm sure you have some serious coin wrapped up in those sticks, but I'm as anxious as anyone else to see how they perform.
TARM
HRT,
That is great thank you. Its very helpful to see them comparatively like that. I recall you posting solenoids once back awhile ago. That is one key part that would add good deal positive to even current design and significantly boost over all perf as part of a systemic redesign. I was surprised that was not an early thing that was designed and offered by injector builders.
What ICP pressures have you been able to hold in your testing with the those solenoids?
One those barrel and plunger sets what tolerances were you able to consistently hold to?
Hotrodtractor
Mingo, Ohio
HRT,
Solenoids have nothing to do with holding ICP pressures. In fact I have tested very high pressures on a bench using stock solenoids.
The tolerances.... lol.... lets just say it is the closest slip fit you have ever seen. If you hold the plunger in your hand for a moment it will no longer fit in the barrel. It required grinding to be completed in an environmentally controlled machine shop - then sending the components to Europe for some very proprietary coatings - then shipping all the parts back and measuring each one using custom manufactured gauges for measurement then matched to a mating component to get the desired slip fit.
96F350KID
Nokomis FL
Did you ever fire them? What was the outcome of the ccs? I just started to have issues with my top HPOP. All I did to curb my low pressure oil drop was to run a hard line from my oil filter housing to the top of the res for more supply as at 3100rpm it would drop to 1-6psi of oil pressure which still means it was filling but not at the desired pressure I wanted. 400/300 b's would hold 3400psi at 2.9ms. On the bench they hit 396ccs at 3000psi @ 2.9ms. No poppet float yet, I don't know how long they will last at that pressure but time will tell. My goals are a money pit and I will probably go broke trying this my self but I want to do it to do it. The other set of Bs i have I'm playing with along the same lines as what HRT has done. I have a company that makes fuel components for NASA up the road for me and they have the capabilities to machine the plunger and barrel to the specs I requested. Poppet modification is my next step to look at trying to use to the stock solenoids. I don't have the knowledge to make larger ones like HRT has done a few years ago. It seems most have made it to his area and changed platforms due to the increased expense. However most of the other platforms have $30K+ into them now. Approaching the $20k mark I'm not stressing the cost just yet.:lol:
Big Bore
9000ft in the CO Rockies
At this point in the discussion I'm very surprised that an isolated/dedicated hydraulic fluid system using a hydraulic fluid reservoir and high flow high pressure hydraulic pump hasn't been thrown into this conversation. Lott once told me he had designed (made?) a plate that allowed attachment of tubing to the injector for recovering the fluid. I have thought that a banjo bolt type attachment at the injector outlet would work for recovery of the fluid. I'm fairly certain HRT and I have discussed this in passing also. Not sure its even relevant to this discussion, but one major choke point in oil supply is the IPR, and HRT had made a couple versions of dual IPR blocks allowing multiple feed lines to the heads. I have one and a set of custom lines that I was going to use with a long gone Termy setup, and there was a guy doing the same with a home made Gen 3. In any event, fun read after having been AWOL from the forum for a bit, please continue and forgive my furtherance of the derail. :D
96F350KID
Nokomis FL
That can be avoided if you use dual HPOP no? If a single 15* can run 6 BD injectors at 4.6MS why couldn't a single HPOP be used to run 4 injectors of a larger size with no drop? That was Gary's entire point to 4 feed lines on his big single pumps but still only used a single IPR. By using 2 pumps with 2 IPR valves that cuts the duty in half as well as keeps both heads supplied.
Big Bore
It also reduces the heat from the friction of forcing the oil from not one, but two pumps through one IPR. The IPR outlet line on a set of one brand of duals was incredibly hot, melting any plastic parts associated with the fittings. It was also a pretty small line. My opinion is it was causing a lot of unwanted disturbance to the oil in the form of aeration in addition to the heat as it squirted through . The remote dual IPR block galleries are massive, and it is removed away from the engine heat which also allows for adding additional cooling options, I believe HRT addressed this in later models of his block. So yes, in theory the dual pumps were supposed to solve the oil supply problem, but running both pumps to a single IPR was a step backwards IMO, not to mention having them pressurizing each other (described as balancing) before sending oil to the IPR. The other dual pump setup used two IPR's but kept them in the stock location which also IMO is bad due to very poor access to a known problematic part, and again the heat soak issue, which could also be a source of the common failures. Filtration before the IPR's would help with the failures too I think.
96F350KID
Nokomis FL
Right but dual pump setup like BTS now FFD use two pumps with two IPRs in factory locations. As far a heat for large HP applications max run time is less than 30 min. That is of course you try to tow and daily with a 13+ year old truck trying to make 800+hp.
Big Bore
Yea I didn't think a lot of that tangent was an issue other than supply, which was why I brought up the isolated fluid idea.
who doesn't?
TARM
Guys if you do the math dual HPOP would not support moving more than 300cc in 45 degrees of crankshaft rotation.
The reasons we area able to move the oil we are today is because of the restrictions in the injectors. You can of course also use more degrees of rotation but then its not effectively hitting the window and you either spike CP or its wasted out the tailpipe.
I laid out the math in the T4 thread: It actually makes much more sense in this thread so I will C&P it below .
IIRC the orignal CAT Heui setup used external oil lines to the injectors before moving to internal head rails. They also use a accumulator instead of reservoir for the HPOP oil source.
Sorry I had to double check some of my numbers and have not been home much over the last few days to reply on this.
Yes because the nozzle was not the limit at those levels the limit was the oil fill and exiting the injector. When that happens you see a drop in injection pressure and you basically get actually less fuel because the oil side can not keep up with the speed the piston would have to move to keep up fuel psi.
I have to still look some more for the graph I made as it makes this very easy but here are the rough guide lines to the mechincal PW window in ratio or rpm and include the added commanded delay( commanded versus actually once the injector actual pushing fuel out the nozzle.
Mechanical Window= 42°-45° degree crank shaft rotation(CSR).
crankshaft rotation degree (CSR)to rpm per milisecond(MS) or pulse width (PW). ( in otherwords 1 ms = __°@ ___ rpm) Then we must add 0.5 to this to see what we actually COMMAND the PW to be as we must account for the delay between command and actually event.
You then have to factor 2.3-2.5hp/cc.
But you have to have those CC in the upper RPM band or the tq is just too high down low as you have to remember TQ is only one part of power twisting force but in and of itself is static. You have to have movement or work done which is the flywheel rotation in the case of these engines. Torque starts to decrease as RPMS increase because air flow and efficiency of use is limited. The more rotation in a minute the more air its using per given time. This is how HP can keep increasing while TQ decreases as more work is being down via the faster RPMs. (The air factor is why we can get there when we use NOS as it greatly increases content and density of O2.)
So knowing this and knowing from lots of observation of diesel motors we know we can only make about 2.3 to 2.5RWHP per CC (1000 shot) of fuel ( fuel only).
Lets use the current ultimate goal for a HEUI 7.3 which is to make 1000hp fuel only to the rear wheels. To be optimistic lets use the upper limit of 2.5hp/cc
1000hp/2.5hp = 400 cc
So we need 400cc of fuel to get to 1000 hp and to do that we need a certain amount of RPM to use both the air and fuel to be burnt efficiently enough to keep this ratio of fuel to HP. We also have to limit tq to something "A" that will keep the engine together and "B" that can be something we can at least use a large % of. To get more HP up top we need to correspondingly increase the TQ levels at higher RPMS.
I am going off memory here as I have nto found the chart yet but IIRC:
The effective fueling window or PW window is about 45° of crankshaft rotation for each cylinder. I think it was roughly 6° of Crankshaft rotation per 1000 rpms =1 ms of PW time. You can then subtract this fro the 45° to see how many MS of PW time you have for a given RPM. This is the actual mechincal window. There is still injector delay thus we need to account for this to get commanded PW as we have in the tunes. That delay should be constant and I beleive is 0.5ms. That needs to then be added to the mech PW window to get the commanded PW.
We will use best case scenario of 45° available crankshaft degrees.
Total Available Pulse Width (TAPW) in Milliseconds for each rpm bracket
1000rpm = 06.0° CSR / MS = 7.50 ms TAPW = Commanded: 8.00 ms
1500rpm = 09.0° CSR / MS = 5.00 ms TAPW = Commanded: 5.50 ms
2000rpm = 12.0° CSR / MS = 3.75 ms TAPW = Commanded: 4.25 ms
2500rpm = 15.0° CSR / MS = 3.00 ms TAPW = Commanded: 3.50 ms
3000rpm = 18.0° CSR / MS = 2.50 ms TAPW = Commanded: 3.00 ms
3500rpm = 21.0° CSR / MS = 2.14 ms TAPW = Commanded: 2.64 ms
4000rpm = 24.0° CSR / MS = 1.87 ms TAPW = Commanded: 2.37 ms
4500rpm = 27.0° CSR / MS = 1.66 ms TAPW = Commanded: 2.16 ms
5000rpm = 30.0° CSR / MS = 1.5 ms TAPW = Commanded: 2.00 ms
So we need to be making peak HP somewhere in the 4.5K-5K range. Thus we need to be able to dump at least 400cc of fuel in a commanded 2.0-2.20
But now consider the oil side of things. But do not consider it in terms of total flow per minute but consider it in terms of flow rate per time or crankshaft degrees of movement during a injector PW time period.
What does it take to move 400cc of fuel. We always talk in the flow bench flow rates but this does not really give the accurate picture. They are done per 1000 shots so the differences can be read easily.
400cc / 1000 shots = 0.4 cc per injector firing.
oil to fuel ratio of a hybrid = 5:1
0.4cc of fuel = 2cc of oil displacment
Standard 17° HPOP displaces 7.2cc per revolutions and rotates @ 85% crankshaft rotation.
That is a perfect world. Lets just drop off the 0.2 cc to take care of the real world inefficiencies that are in the system and that is conservative IMO.
Now everyone is going to be running at least a dual hpop system at that level So for arguments sake we double the displacement amount so 14cc per full HPOP gear rotation. But its 85% of the crankshaft so we need to reduce this to displacement per crankshaft rotation or for every RPM level we will have to recalculate for the 85%.
14cc x 85% = 11.9 cc per CSR of 360°
We all I think understand that the higher the RPM of the engine the more oil the HPOPs are displacing in given period of time. Thus if there is not enough oil displacement a given RPM no rpm below that will be able to displace more oil. So we are all on the same page now.
If we look at the chart above it gives us a chart of crankshaft degrees of rotation for a given time period in this case per millisecond.
We have to keep in mind with only have a limited amount of crankshaft degrees of rotation to inject our fuel. This means we are always limited by the fixed amount of CSR being 45° but time or PW window varies with RPM ( getting shorter)
The crankshaft degree rotation window being fixed is critical as it gives us a maximum rate for oil flow per RPM. You get forget about all the PW times as this is the best or most the HPOP system can support or its max displacement flow rate.
So we know that a dual 17° HPOP setup can possibly displacement 11.9cc of oil per 360° crankshaft rotation.
We know the maximum crankshaft rotation for a given cylinder that will ensure the fuel hits the piston bowl is 45°.
45° is 1/8 of the full 360° of rotation or 12.5%
11.9cc per CSR x 12.5% = 1.4875cc
1.4875cc This is the most oil a dual HPOP can displace per injection event regardless of the RPM. So any PW window is going to have to be a fraction of this or guess what P1211 !!
The rotational degrees all works out as we have a 8 Cyl 4 stroke engine. For every 360° of rotation 4 cylinders fire or 90° of rotation per cyl of that 1/2 of that piston movement in the window that given injector angle and spray pattern will have the majority hitting the piston bowl where it belongs and can be used.
Now you begin to see why you need big oil even with stock B codes and why as the nozzle size goes up and increase fuel flow per time you need more oil volume.
Now what do we have
Fixed ratio of oil to fuel at the injector: 5:1 (Forget any of the oil restrictions)
Maximum displacement of HPOP oil per CSR: 11.9:1
Maximum crankshaft window for injection: 45°
Maximum HPOP oil displacement per 45° CSR or per injection window: 1.4875cc
This means we can see, mathematically, what is the most fuel a dual HPOP using a "hybrid 5:1" injector can supply for a given PW at full 3K psi
1.4875cc / 5 = 0.2975cc per injection event
0.2975cc x 1000 shot = 297.5cc of fuel
We can see the maximum amount of fuel a dual 17° HPOP using a hybrid injector can support its injection pulse. Or the amount of oil displacement available or any injector by computing the hydraulic ratio This is also factoring in the assumption that there are no oil flow restrictions in the injector or they have all been fixed which of course is not the case and is the reason we do not see current hpops fizzing out..
To see this thru consider what we have seen in terms of RWHP There is a HP:fuel cc ratio range you see thrown around quite a bit in the P-pump and HEUI world its 2.3-2.5 HP per cc of fuel.
Is it not interesting that this seem to fit very well with the max HP we have seen in HEUI fuel only?
300cc x 2.3-2.5cc = 690-750HP Interesting coincidence isn't it!?!
TO BE VERY CLEAR: I am not saying more fuel can not be injected as it can just not inside this window where ideally needs to be (to keep it in piston bowl) if you want to keep that engine together and or make HP not just more smoke or for other reasons such as cooling egts as done with puller setups.
Obviously a Gen III with its gear pump can do even more but when you look at what it takes to get 400cc of fuel which is 2cc of oil run the numbers are you will see that standard dual hpops falls 25% short on needed displacement and that is maxed out.and then add in the real world decreases in efficiency that happen at the higher flow rates and the dynamics of the oil moving in and out of the injectors that maybe push it as well.
Next consider how much oil that is also needed for the engine lubrication and how much extra is needed to be pulled thru the HPOP res to support this system at these flow rates. What happens a higher RPM but lower demand i.e holding a gear longer but light throttle. The injectors are using very little of the oil so its all being bypassed but still the HPOP pumps are fixed to rpm so they are pushing all this oil thru those little IPR orifices and what about the LPOP that is to support this amount of oil flow to the HPOP res.
Consider that currently a dual HPOP is pulling 11.9cc per CSR of oil and we need a min of 25% more.
3000 rpm instead of 9.43 gallons per minute going thru the HPOP res it will now need to be 11.79 gallons per minute and to be frank I think we actually need more or that other issues in the system may start showing itself. Can even the DS HV LPOP even keep up with this demand and still hold need flow thru the engine or do we need a external gear or belt oil pump to support a HPOP system of this size?
It seems that if all the oil restriction issues were gone from out hybrid injectors and they kept the 5:1 ratio even the DS HV LPOP could not keep up with the demand needed by a hpop system that could supply the needed oil to run those injectors without oil side restrictions once we past this current limit threshold.
This also gives clear evidence why a using B code with standard Barrel and plunger ratios even if you could flow all the oil in and out without restriction could not be supported by even most big oil.
Take a 6:1 ratio for 0.4cc of fuel instead of 2cc we now need 2.4 cc or another 17% more so instead of 25% deficit its 42%
Point being we have oil supply issues and or oil need issues. This is why any new injector parts IMO need to have a lower B:p ratio and that other adjustments inside the injector can be made to still get higher resolution and thus injection quality.
Look what happens if we change that injector ratio to 4:1 or then 3:1
4:1 ratio
4:1 ratio = 1.6cc oil : 0.4cc fuel
3:1 ratio = 1.2cc oil : 0.4cc fuel
We are now in the range of oil displacement that dual HPOP and certainly GenIII setups can support for getting the fuel in a window for good clean power.
I wanted to bring this up as it has been brought up before once or twice over the last 15 yrs but it seems to be pushed aside, discounted, heads in the sand sort of response, and nothing done about it; just going with the status quo where we have not really advanced much of anywhere in terms of making more peak power. Yes we have come some way in tuning etc and learning how to keep the bottoms together better but we could have oh oh so much more if some changes were made to the hard parts such as the injectors rather than using OEM and just mix and matching maybe a bit of machine work here and there but never addressing the real fundamental problems holding this system back. With those changes 1000RWHP+ is without a doubt doable and with heavy NOS fogging could with some luck be knocking at 2K door.
Big Bore
While your post was overflowing with great information, I thought this was noteworthy. I would also be interested to know what kind of oil/fluid they used.
One other key point you made was the maximum usable pulse width, I saw a post earlier in the thread with some pulse width numbers at higher rpm's that were over double the usable pw.
TARM
I thought to prevent the float of the poppets at higher ICP we needed a stronger poppet spring and also needed a stronger solenoid to overcome the increase pressure and allow to work quicker. I could be confusing things though as I recalling it from a conversation and few posts from years ago. I thought about the time you had posted the solenoid pics. I thought this was the cause of the poppet flutter.
Ok I went digging into the old threads on PSN and found I think where you posted the solenoid pic and the talk about poppet flutter:
http://www.powerstrokenation.com/forums/34-smack-talk/79902-nozzles-vs-tuning-12.html ( this is where the the topci comes up by Charles (Chillin)
To handle higher injection control pressure you need to address the tendency for the poppet valve to lift off pre-maturely, or to completely hang through 360* of cycle. At the same time, whatever you do to combat this must be accounted for in the strength of the coil to then lift this same valve off its seat when you do want to fire the injector.
Basically, valving becomes more complicated when you attempt to valve higher pressures.
Obviously the other component of the limitation equation is rate. Rate of flow. And not rate of fuel flow through the nozzle, but unfortunately, rate of Rotella flow through the injector. A serious limiting factor.
Here is my question after the post you put one pic that showed the solenoid but the pic is not there not even a dead link but the info I think is still of interest so:
HTR,
As far as I can tell all of yiour valve covers are custom made. How much did these custon selinoid packs add to the OAL of the injector? What kind of increases do you expect in their performance?
The final length of the entire injector ends up in the 1/2" to 1" longer region depending upon final packaging and wiring of the solenoid. I'm currently remaking the molds to the final configuration based on some prototyping that I have been slowly working on over the last year. When I started down my current path three years ago - I had a much different idea of what needed to be done that where I have ended up. Einstien said it best when he said "Make everything as simple as possible, but not simpler." When the final solenoids come out of the molds in the next couple of months I'll post pictures - my prototypes are a bit crude and a bit too revealing to show anyone. Would it interest you to know that there are well over 100 individual pieces that come together to make a single solenoid, not counting the tooling for the machining and casting?
As far as performance - my goal has always been 1K Hp on fuel alone. Once I achieve that or fail miserably at trying to achieve that - then I am done working on the HEUI system.
All along this has been a project for me because so many people have told me it can't be done - so in my free time I do what I can to progress towards this single goal - and evalutate any issues that arise along my path - go back and revise concepts and ideas as things are proven or disproven, etc... That was my whole reason for turning the red truck into a pulling truck in the first place - several people told me that I couldn't make the power to compete - so two years later I installed a motor that I hand built with lots of goodies - some well known - some unheard of before on a PSD and started my quest for 300 feet. Once I got the point where I was starting to make enough power to get noticed by the competition the driveline just would not hold - both due to the torque levels being applied to the shafting and a small bounce that I could not (at the time) get out of the truck on initial take off. 37 spline Dana 80 shafts became a weekend treat, I had enough issues with 1480 driveshafts that the guys at the driveshaft shop would drop what they were doing and meet me at the door to get cranking on my parts immeadiately to get me going. Once I realized what it would take to progress to the next level I knew I had to sell the chassis and build a new truck.
It looks like all the pics in the older threads are gone for some reason. Take the pic you posted of the barrel and plungers in the original thread on PSN you posted it in that pic is gone. No link nothing. Would not even known there was a pic if it had not bee referenced in the posts.
Here take a look:
A Preview of Things to Come
I even ran some rather deep google searches to check there cached images and see could not find the solenoid pics.
TARM
I think it was engine oil. Actually there was a historical tech doc I found one day that gave the entire history of the HEUI and that is where it had it. IIRC it used engine oil same as today just that by using external tubing likely allows more traditional head design. But if feed and exit lines were external that would sure be easier. But I think durablity is likley why they changed. Look what we deal with just with 2 HPOP hoses and a rupture can you imagine with 8x2.
Yes that is what actually had me posting in the T4 thread as the conversation had gone to a certain turbo not having enough air for a certain injector as it was hot and smokey. My point was the PW was way to much for the given flow etc. So I put down the info to give some context. IIRC the tune was commanded well over 3 ms at high ICP with a 200% nozzle and a 38r which was emptying the injector. Take a look in the middle to last few pages of that thread to see the situation.
All this info was understood by the top guys 6-10 yrs ago but now we have many new members that have not dug thru the archives.
Its actually rather amusing as some of the people that carry certain reps and some of the posts they made. We all have to learn sometime. I surely was one that benefited greatly from the info posted in the 08-11 time frame. I think it was in that time frame were at least publicly on the forum there was a much better understanding of how and what it takes for a heui system to work. The last part was tuning and having it done on a real diagnostic engine dynos as Swamps ended up with. TQ and CP levels went down, the injection window shrunk, peak HP RPM band shot up, blocks started living at much higher HP levels. Hell back in 08 you had forge rodded blocks windowed with 400HP even less. Crazy SOI in the tunes etc..
96F350KID
Nokomis FL
The reason that theory has been pushed aside is because it doesn't take into consideration the pressurized oil inside the head rails. If your theory was correct common rail trucks would fall on their face stock. It's late and I can go into more detail if need be but its late right now.
morefuel
Chico, California
I'm curious how the oil rails act as a accumulator. I thought liquid didn't normally compress well or is there something i'm not understanding?
superpsd
Missouri
. If liquids did not compress well we would not have hydraulics LOL
Would be a fun experiment to setup individual exhaust lines that feed a large reservoir and add a kidney loop filter system and cooler. Would need to fabricate and modify the body tops for a closed loop system. Likely more work than is worth.
If pressure is holding in the feed rails your likely we'll. Remove the injector restrictions and if you can't hold ICP then more oil is needed.
