psduser1
Cracked nozzle?
I think the turbo blew a seal. Oil is in both up pipes and the turbo has oil all around it. Took turbo off, got the compressor wheel off and turbine wheel and shaft out. Got the turbine cover still on though. How do I take that off?
Like zeb said, a blown turbo isnt gonna put oil in the up pipes. And a blown turbo wont cause the sound you were hearing. Sounds like an injector was loose to me, but if they were all good, that leaves motor issues. Possibly bent push rod, broken rocker, or something along those lines id think.Can a turbo get too much? Like too much to blow the seal out?
I’m gonna get a used S471 and try it
?Pushrods straight?
Sorry I didnt say you said it first... Figured it mightve needed to be reiterated though...?
No worries wasn't ment that way. He never responded saying either way..Sorry I didnt say you said it first... Figured it mightve needed to be reiterated though...
Lol I knew it wasn't, I realized after seeing your response though, that I hadnt said you said it... I hate looking like I'm that smart and thought of something in my own...No worries wasn't ment that way. He never responded saying either way..
If injectors are out then pull the push rods quick and double check them. Roll them on a flat surface.. mirror would be best actually.I do need to cap the lines then fill the Rez. Injs are out so no go on rails.
