imelmo
- Joined
- May 18, 2011
- Messages
- 6,633
- Reaction score
- 2
So I have my truck back now. Had a couple things to button up like replace the fuel pump, put intercooler boots on, replace the ficm relay and a couple other small things. Only thing not installed right now is the coolant reservoir.
Tried to start it. It turns over just fine and will hit but won't stay running. Tried using a little ether and it made it run a little longer but it still won't run on its own.
While it was away all of the oil and all of the fuel was drained from everything though, so is it just going to take a while for everything to get filled back up and do I need to just keep cranking on it? Or should I be checking for anything else.
Also, when it does hit, if I continue to crank on it the truck will not hit again.
Any ideas?
Any ideas?
