rclb 1999 f250 Fummins 6speed (utah)
TRUBBS
Balls Deep
ok guys, i got this posted up on psN since thats where i had spent most my time, but figured i would post it over here to for the ones that dont associate over on the nation any longer. ill get on here as much as possible to answer any questions but texting is usually the best/eassiest/fastest way to contact me 801-866-9947
link to psn-
http://powerstrokenation.com/forums/showthread.php?p=1652377#post1652377
1999 ford f250 superduty, powered by a 5.9l cummins 12valve
sellin my '99 fummins, truck has just under 190k miles
2007 front end swap
harley replica head lights
35w 15k HID kit with both high/low beam
'07 tow mirrors with marker lights
'07 fender badges
18 inch chrome wheels
near new 33inch toyo at tires
3.73 gears with posi lock rear end.
new breaks last spring
new ball joints last spring
new shocks last spring
brand new clutch master cylinder
brand new clutch clave cylinder
brand new ford alternator
brand new belt
%5 window tint.
2inch lift/level kit.
the inside of the truck has been coating with sound proffer much like dynamat
FRESHLY REBUILD '94 P-PUMPED 12V ENGINE
mild pump work
(4k gsk,rack plug,fuel cut delievery valves,afc spring kit,afc barrel's been ground,plate shaved ect...)
18* timing
5x.025 injectors
valair 650hp single disc clutch
ford zf6 transmision
destroked adapter plate
oil pan and valve covers have been coated on the outside with sound dampener.
manifoild has been gasket matched/cermaic coated and header wrapped
tripple electric cooling fan's
shut off for the engine is mounted to a pull cable inside the cab but will include the plug hook up for the electric shut off if you wish to buy one and install it.
fuel system consists of,
3/4" bottom feed fuel sump
3/8" drawstraw from the top
dual lift pumps (stock powerstroke pump feeding stock cummins lift pump)
remote fuel filter
fuel cooler
~*~im sure i am missing plenty of things about the truck, if you have any more questions feel free to text any time or call after 4 Trevor, 801-866-9947 asking 9,500.00 OBO. ~*~
located in ogden utah 84404 (about an hour north of saltlake city)
*THE BAD-
curretly the drivers side window switcher isnt working but we are working on getting it fixed
6th gear tends to "scratch" sometimes when shifting
truck will need to be aligned (drives straight steering wheel just isnt straight from the level, been like that since i bought it jsut never bothered me enough to have it done)
will need new batteries as these are starting to get tired (if let sit for a few days it has a hard time cranking over, i drive it everyday and they havent given me a problem)
no tacomemter
ac lines havent yet been taken care of to make them fuction.
TrailerHauler
Michigan
Good looking ride and not a bad price! Out of curiosity why isn't it intercooled?
Good luck with the sale to!
TRUBBS
Balls Deep
When I first put it together, I tried using the pipes i had & running it backwards trough the I/c but was having problems keeping boots on, so I bypassed it for now. It'll be intercooled this weekend however.
Austin
Parker, CO
I honestly don't know how this truck hasn't been bought yet.. If I didn't have my current 7.3 payment I would have already taken it.
STR8LINE
Barren River Lake, KY
ImIRISHSH
Trade For Nice 07 4x4 Lariat CCSB Black w Tan insides, stock as a Clock 190k Needs an EGR delete and some those custum Tuneing.. GuRu... SUPERD airFlow Twizzler Swurley Thingy's.. Parts InCluded
Cash My way.. Parts Your Way Too
270-670-5958
Matt
TRUBBS
Balls Deep
270-670-5958
Matt
Temping as I need a crew cab but don't wana bother with the hassle of a 6oh-no
TRUBBS
Balls Deep
Back up To the top
Also will most likey be dual feeding the injection pump before the sale also.
TRUBBS
Balls Deep
I agree. Lots of interest & people saying they want it but no one has actually fallowed through
HellFire
If you still have it when i return from Afghan in April...I will buy it off of you without thinking twice:) but i highly doubt that it will still be around.
Cody
NW OHIO
possible trade for 2000 f350 cclb 4" lift brand new paint rust free except for rockers, brand new 2011 take off bed yada yada yada 164k
TRUBBS
Balls Deep
Still getting text's & calls asking if it's for sale. Starting to think about selling it & getting out of the diesel world to buy a house. It's now got stock injectors in it as well as single exit exhaust. New brakes/ calipers up front along with Mooge ball joints & warn 1/4 turn hubs. Don't have to sale it but would let it go for 9,500. Working on getting the wiring gremlin fixed for the windows also just haven't had time working 12-13hours a day
TRUBBS
Balls Deep
bump to the top. will most likly be getting twins built for it next month (hx35/gt4202) and will start and new updated forsale thread then. price be also go up with twin turbos on it...
TRUBBS
Balls Deep
Sellin the little red rocket!! lol good luck with the sell trev.
That's Cody. Had a lot of fun with the truck but now with the new Toyhauler looking for something a little easier to drive with more room.
latest underhood picture
