HoustonRider
Houston, Texas
Im looking for the Heavy Duty All Weather floor mats for the 2011 SuperDuty. I always see em in black, as a set of 3 (fronts and one rear). These are the same ones as the Raptor comes with :)
Whats price on this set (and are they only in black?)
Ford # BC3Z2613300AA
thanks!
dirtboy25
Ft. Scott, Kansas
I need PTM side moulding for a 1999-03 Extended Cab.
you can see below what I need.
8upwitHDs
All parts for 2005 F350 SRW. I want to rebuild the front end.
upper ball joints x 2
lower ball joints x 2
Yellow o-rings x 2
Axel Dust Seal x 2
Wheel Seal x 2
lower ball joint snap ring x 2
Upper ball-joint nut x 2
lower ball-joint nut x 2
o-ring kit (includes 1 snap ring and two black hub seals) (5C3Z1K106AB) x 2
Cotter pins x 4
Studs to connect hub bearing to knuckle x 8
Nuts for above studs x 8
Hub Unit Bearing Assembly x 2
Inner tie rods x 2
Outer tie rods x 2
the ball joint that the trac bar connects to x 1
the drag link ball joint that connect to the pitman arm x 1
anything else that I might have missed?
sunrisefordparts
thanks!
floormats list $91.43 sell $70.40
yes only in black in the rubber ones
Agjake11
Rosenberg TX
need the 08+ driver side tailgate hinge x2, and the driver side tailgate side insert (part that the new style hinge fits into pictured below) x1
hinge should be #4L3Z83430B39AA
http://hotshotracing.smugmug.com/photos/1165111757_Sp***-L.jpg
sunrisefordparts
hinge list $11.47 each sell $8.60 each
as for insert that is only part of the torison rod that runs into tailgate
Agjake11
Rosenberg TX
pm coming on the hinges. but to clarify i have 2 08 gates. one has that piece in the pic and the other it was removed by the PO and so the 08 gate will fit right up to the 99-07 driver side hinge.
