Back pressure ?
mclean
Fort McMurray, AB, Canada
yeah thats what i meant. turn your key on and see what your bp reading is and subtract that from what you are seeing on your DD. Pretty sure that's how you do it.
outacntrl
Clearwater, KS
What would I need to do to figure it out.
What's your elevation? The pressure goes down as elevation goes up. Turn the key on and see what the reading is with the engine off and that should be atmospheric pressure. You need to subtract that from the absolute bp reading you get while it's running.
Rmartin-97
Mcarthur ohio
I dunno what my elevation is I'm in ohio. But on my mini max the exaust back pressure reads 0 with the key on but my barometric gauge on it reads 14 with the key on so doin subtract that from my ebp?
JD3020
Farmersville/Dayton, Oh
If i'm thinking correctly right now, if the back pressure shows 0 with the key on while baro is 14, then its already subtracting 14 for you which means what it shows is what you have. If back pressure showed 14 at idle or engine off, then you would have to subtract 14 to get the BP number.
Rmartin-97
Mcarthur ohio
Now I'm confused again.
JD3020
Engine off or at an idle, if the gauge is reading 14, 14.7, 15, or whatever then that means it is showing you the absolute pressure that the sensor is reading. So its atmospheric pressure, plus whatever pressure is being built. So say if it reads 14 engine off, then when its running and shows 60 pounds of back pressure then it is really 60-14, which is 46.
But if at idle or engine off, and it is showing 0psi, then it is already accounting for and subtracting the atmospheric pressure. So if its showing 60psi, that would 60psi of back pressure.
On my OBS the scangauge shows boost and MAP. Boost at idle or engine off is 0, while MAP(manifold absolute pressure) is reading about 14.7. So the boost reading is automatically subtracting 14.7 and showing me what my boost reading is. When i'm building 20psi of boost, the MAP reading is 34.7
outacntrl
Clearwater, KS
I'm pretty sure ebp is what you want to be watching and if it shows 0 key on engine off then it's already subtracting atmospheric pressure.
Sent from my DROID RAZR using Tapatalk
Rmartin-97
Mcarthur ohio
Yea with the key off it reads 0 on ebp so should I look into a wastegate at 45psi boost 60 psi ebp?
superdutyman97
McArthur, Ohio
Go down to the fisher building and look at the corner stones. The elevation is etched into one of them. I think it's the front left from in front of dads garage
