Who makes a complete front end kit for our trucks?
T.R.P.
I need ball joints. Scratch that, I need everything. I am tired of all the play in the front end. There's not much, but I want it to feel new. Who makes a kit that includes ball joints, adj. track bar, drag link, etc?
I'm looking to replace every single bar and joint on the front end. Thanks!
oldbluef250
Alma Center, WI
just go to the parts store and order the stuff. Assuming you wont need wheel bearings, you will probably spend around $500 for everything. Your steering gear box is also probably worn down as well so even with all new front end parts, you will still have slop in the wheel. A new gear box is around $250 i think. Unless you can tighten the gear lash nut enough to get rid of the play
GreenMachine
RI
the tire club.com hs xrf ball joints for 100 a set. They seemed to hold up well on my truck.
As far as tie rods and drag links, moog stuff blows. Didnt seem to hold up worth a damn. thetireclub.com also has a complete front end kit. not sure about quality.
T.R.P.
I don't want parts store stuff on my truck, though. That's the problem.
Dmstrucks02
Pearland, TX
This, just replaced moog parts on my truck with xrf stuff and seems to be all good for now
GreenMachine
RI
Guess you guys haven't driven too many 6.4's.....
I'll let ya know how mine is when I get it soon.
Lol just messing with you
Ad8 PRODIGY
Orange County, NY
I've driven probably close to 10. Mostly 7.3s and 6.0s. One 6.7 450... all were sloppy. One 6.0 had me correcting it constantly. I guess you get used to it though of course.
Are all PSDs like this? Some more, some less I imagine.
smokedout250
harrisburg oregon
My obs was always all over the road my 07 250 6.0 is actually really tight...y buddy's 2000 all over the place
cfdeng7
CT
My truck has zero slop in the steering. If there is slop, somethings worn out.
Lowdown89
Travelers Rest , SC
I couldn't get the tire club page you guys mentioned to load is that the only place that sells the xrf stuff? Is it that much better than moog? Whenever I put the lowering kit on my truck I plan on replacing as many bushings, tie rods, etc that I can to get my truck to driving as close to new as well
GreenMachine
RI
My 2000 had sloppy steering because I replaced every front end piece except the track bar and steering box.
My moms excursion with a 7.3 we put a redhead box in, and the thing is tight as ballz. Most of the front end is original ford with 180k on it.
I've put ball joints in it, and maybe a tie rod. Goes to show you when your anal and baby a vehicle it lasts. My old man treats that damn thing like a child.
