superduty swap parts/heads/rods/ other stuff
vanderchevy18
Benton, Ks.
I have everything to turn an obs motor into a late 99.
Exhaust manifolds
Up pipes
intake plenum
front cover
hpop resivour
turbo (tight with no play)
Pedestal
ic pipes
Ic boots
accessory brackets
$650
Stock heads (1set sd 1 set obs)-$250
Good stock forged rods (2sets 1 sd & 1 obs)-$150
3 Good Stock sd turbo's w/ pedestals-$250 each
K&n cold air ntake- $100
Stock fuel bowls (with fpr shims for 65psi & deadman valve removed)-$35 each
Obs fuel pump- $25
Complete superduty stock intake-$30
Good Stock 4x4 4r100-$500
Superduty 3:73 axles-$650
Good T6 HT3B turbo-$350
All prices do NOT include shipping.
PM me or text 316-650.1063
vanderchevy18
Benton, Ks.
Exhaust manifolds
Up pipes
intake plenums
Pedestal
Ic boots
$400
Stock heads (1set sd 1 set obs)-$200
Good stock forged rods (2sets 1 sd & 1 obs)-$100
3 Good Stock sd turbo's w/ pedestals-$200 each
Stock fuel bowls (deadman valve removed)-$30 each
Obs fuel pump- $25
Good T6 HT3B turbo-$300
Pcm and hpops sold.
Prices and parts have been updated.
buschpoweredstroker
Upstate NY
both sets of rods were out of only 1 motor per set? (no mismatched rods) only reason i ask- I bought a set of rods from allstar once and when I went to have them balanced... the guy told me he couldn't balance them because the weights were so far off... he said they couldn't have come from the same motor
vanderchevy18
Benton, Ks.
If you buy a set of rods they will all 8 come from a single late 99 powerstroke. Once those are sold the next batch of 8 rods will come from a single 95 powerstroke. How's that for clarity
vanderchevy18
Benton, Ks.
Yeah well it wont happen this time. I ain't pulling these motors apart unless something is sold, and its just too much work to pull 2 motors apart just to mix up the rods! LOL
vanderchevy18
Benton, Ks.
I also forgot to mention that I have 2 complete oil coolers. Make offers on them. If you need something that I haven't listed just let me know. I probably have it.
vanderchevy18
Benton, Ks.
Sure do! The only things I've really got left are those, the obs rods, the heads, the k&n, the stock intakes, and the fuel bowls.
Powerstroke Cowboy
Montana
I know this is like a shot in the dark Chris.. Would you happen to have a 99-03 intake spider Or just the Part of the spider the connects to the turbo. And would fit a GT42 style turbo???
Thanks!!!
