7.3psd97444
I have for sale a Viking Horns (PN: LL-103B) Heavy Duty Air compressor. 200 psi max, 100% duty cycle, Never been used. Only hooked up to power one time for 2 seconds to make sure it works, and it works great! Just have no need for it anymore. Has built in a pressure sensor that will shut the pump off at 200-250 psi (tank pressure) and also a temperature sensor that will shut the pump off at a certain temp. from being used continuiosly to much. To keep from over heating. Included with it will be a external pressure sensor that taps into the air resivior/tank and wires inline with the ground circuit and turns the pump on at 170 psi and off at 200 psi. As well as an in line fuze for the power circuit and a air cleaner/filter. As well as the mounting hardware that came with the compressor when i bought it. I will note that it is VERY quiet in operation, I know that most people dont like these to be noisy obviously.
Asking $175 PLUS shipping. Post on here for any questions and PM me if your interested. Thanks.
![488150_523551080993478_2002820691_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-b.xx.fbcdn.net%2Fhphotos-ash4%2F488150_523551080993478_2002820691_n.jpg&hash=6feb2b99bcc498e5d6ccf980d2673181)
