Multi-function switch dis-assembly?
JCart
Kamloops, British Columbia Canada
Hi Fellas,
Posted this over on PSN too...
I wanna install a micro toggle switch in the end of the multi-function switch and run the wires inside the arm, anyone ever pulled one apart? It looks like it snaps together but I don't want to start yardin on it and break it.... Ideally if I could get the end rotary cap off (windshield wiper knob) drill a small hole in the end to install the Mirco toggle and run wire inside down close to the base would be cool.
Any insight would be apreciated,
thanx,
jrc
_______________
Zmann
Your going to poke your Eye out!
LOL
whats the switch for ?
Zmann
lol gotcha
I found these cool voice recognition relays for different stuff no switch needed
Zmann
well if your interested??
I found those on the same isle as the Electric Turbo chargers
LOL
Bobby@cp
Only problem I see is that it doesnt take much force to flip the multi function lever up or down to activate a blinker....
JCart
Yes good point, was thinking of using a micro toggle switch (in addition to actual switch size to fit in head). The other thought I had was to use a long lever toggle, provided it wasn't too long. Currently working on a bracket to attach near the end of the multi-s arm that will house the thinking now a long toggle...
jrc
Tom S
I think I would get me a junkyard one to practice on. If nothing else one from a Taurus or something. How about a link to the lights you want to run.
JCart
http://www.visionxusa.com/LED-Solstice_Series/c1_48/index.html
Have a pair of these mounted in the bumper holes currently.
jrc
POWER-STRUCK
Indiana
all the wiper contacts are in the end of the switch and the base of the lever already has alot of wires so its a no go! ever thought about duct tape, zip ties, bubble gum? lol sorry i had to say it! maybe you could just try a logical place to mount it like the dash or just wire it to the headlamp switch since they are such a low wattage
JCart
So what i'm thinking now is to clamp a fitting that will hold the switch onto the Multi-switch column toward the end of it. Not as clean looking as installing in the end of the M-Switch but should still be functional....
jrc
Tinman23
I agree, so discreet. I had to look at the pics for several seconds to know there was even a toggle on there.
LOL...awesome.
